Component: LED (5mm, PCB) ()
| Author | Matrix Ltd |
| Version | 1.1 |
| Category |
LED (5mm, PCB) component
An industry standard 5mm diameter LED. Any color may be chosen, and the leads trimmed to length.
BASICIO
