Component: LCD (Adafruit, 16x2) (Alphanumeric)
| Author | Matrix Ltd |
| Version | 1.8 |
| Category | Alphanumeric |
LCD (Adafruit, 16x2) component
Adafruit OLED LCD display capable of displaying 2 lines of 16 characters.
Please click here for the component source code: FC_Comp_Source_lcd_Adafruit_OLED.fcfx
For the LCDs to work with the Flowcode LCD component they need to be connected up in 4-bit data mode.
The 4 data signals actually go to the upper data nibble on the LCD as shown below.
A simple example that shows how to use some common functions.
| Clear | |
| Clears the entire contents of the display. | |
| PrintString | |
| Breaks down a string of text and sends it to the LCD via the private RawSend(byte, mask) macro | |
| Text | |
| PrintAscii | |
| Takes the ascii value for a character and prints the character | |
| character | |
| Holds an ascii value. | |
| PrintNumber | |
| Based on v5 macro, will allow you to print a number. This is limited to a signed-INT, -32768 to 32767 | |
| Number | |
| ClearLine | |
| Clears a single line on the display before moving the cursor back to the start of the line to allow new data to be displayed. | |
| Line | |
| Cursor | |
| Moves the cursor on the LCD Display | |
| x | |
| y | |
| ScrollDisplay | |
| Scrolls the display left or right by a number of given positions. | |
| Position | |
| Holds the number of positions to shift the display | |
| direction | |
| 0 = left, 1 = right | |
| Start | |
| Startup routine required by the hardware device. Automatically clears the display when complete. | |
