Component: Potentiometer (Panel) ()
Revision as of 17:54, 9 November 2022 by Wiki bot (talk | contribs)
Version 1.4
Category
Potentiometer (Panel) component
Analogue potentiometer with chicken head style pointer.
Please click here for the component source code: FC_Comp_Source_pot_Panel.fcfx
Potentiometer Example
Start Angle
Sweep Angle
Retain Value
If yes is slected After saving your project, the ADC value will be retained when your project is reloaded.
Settings
VRef voltage
VRef option
Conversion speed
Acquisition cycles
Bit Depth
