Component: Switch (Toggle, Panel) ()
Revision as of 17:54, 9 November 2022 by Wiki bot (talk | contribs)
Version 1.1
Category
Switch (Toggle, Panel) component
Miniature toggle switch with metal tamg - solder lugs and nut for panel mounting.
Please click here for the component source code: FC_Comp_Source_sw_toggle_panel.fcfx
Here is an example Flowcode program to read the value of a switch. FC6 Icon.png Switch
(5V / 11K) * 10K = 4.54545V
Fc9-type-5-icon.png Connection
Chip pin to which this switch is connected.
Fc9-type-16-icon.png Polarity
Sets whether the pin should go high or low when the switch is activated.
Fc9-type-14-icon.png Debounce (ms)
Time in milliseconds allowed for the pin to stabilise following a change of state. NB) Debouncing is only used when reading the switch state with the component macros. Chip pin is NOT debounced.
Fc9-conn-icon.png Simulation
Fc9-type-16-icon.png Operation
Latching - click the switch to turn it on, click again to turn it off. Momentary - click the switch to turn it on, release the mouse to turn it off.
