API Sound.LoadWav
Revision as of 13:15, 14 May 2013 by JonnyW (talk | contribs) (XML import API changes)
<sidebar>API contents</sidebar> Loads a wave file into memory, providing the values needed to play it
Class hierarchy
Sound
LoadWav
STRING Filename
The formatted file to load into memory
BYTE[] Buffer
A buffer to write the wave data to
UINT SampleFormat
Variable to receive the format of the samples
This parameter is returned back to the caller
ULONG Elements
Variable to receive the number of sample elements to play
FLOAT SampleRate
Variable to receive the wave source sample rate
BOOL
Returns true if the operation is a success, else false
  • Add to a calculation icon:
    result = ::Sound.LoadWav("filename", _arraybuffer, return_sampleformat, return_elements, return_samplerate)
