Component: Control (AllCode)
Revision as of 14:39, 16 January 2023 by Wiki bot (talk | contribs)
Category AllCode
Control component
Drives the Matrix Control hardware via the AllCode API.
Please click here for the component source code: FC_Comp_Source_Control_ComponentSource.fcsx
Fc9-comp-macro.png SetAutoPrescaler
Configures the automatic mode prescaler, for running really slowly. Defaults off so no need to call this unless you are using it.
0=Off, 2=Div by 2, 3=Div By 3 etc
Fc9-comp-macro.png GetOutput
Gets the output value as an integer value betwen 0 and 100 representing the output PWM duty
Fc9-comp-macro.png SetAutoOnOff
Enable the auto PID control using the on-board microcontroller
Range: 0-1
Fc9-u8-icon.png - BYTE Enable
0=Off, 1=5Hz, 2=10Hz, 3=20Hz, 4=50Hz, 5=100Hz, 6=200Hz, 7=500Hz, 8=1KHz
Fc9-comp-macro.png SetWIFIPort
Configures the WIFI Port number. Default 1245.
Fc9-u16-icon.png - UINT Port
Default 1245
Fc9-comp-macro.png SetAutoPIDFlip
Controls if the PID response is flipped, a negative response vs a positive
Fc9-bool-icon.png - BOOL Flip
Default: 0=Not Flipped, 1=Flipped
Fc9-comp-macro.png SetBluetoothDetails
Configures the Bluetooth device name and pin and stores into the none volatie memory onboard the robot arm. Call the SetBluetoothMode macro after this to action the change.
Fc9-string-icon.png - STRING Name
Bluetooth Device String, Max 20 Characters
Fc9-string-icon.png - STRING Pin
Pin String, 4 Numeric Characters e.g. "1234"
Fc9-comp-macro.png GetDataArray
Collects a data array from the Control board. Returns number of samples collected.
Fc9-f32-icon.png - FLOAT data
Fc9-comp-macro.png GetWifiIP
Collects the IP address of the robot arm WIFI connection.
Fc9-comp-macro.png SetWifiDetails
Configures the WIFI SSID and Password strings and stores into the none volatie memory onboard the robot arm. Call the SetWifiMode macro after this to action the change.
Fc9-string-icon.png - STRING SSID
Netword ID String, Max 32 Characters
Fc9-string-icon.png - STRING Password
Password String, Max 32 Characters
Fc9-comp-macro.png ResetToBoot
Resets the board into bootload mode for reprogramming. Comms port will be closed on calling this macro,
Fc9-comp-macro.png SetAutoOnOffParam
Sets the Hysteresis parameter for the Auto on-board On/Off
Fc9-f32-icon.png - FLOAT Hysteresis
Hysterists in real world units
Fc9-comp-macro.png SetWifiMode
Configures the WIFI mode. When enabled the control system can either create its own WIFI network or join an existing WIFI network,
Fc9-u8-icon.png - BYTE Mode
0=Disabled, 1=Host Network, 2=Join Network
Fc9-comp-macro.png GetPIDComponent
Gets one of the PID controller output components in real world units
Fc9-u8-icon.png - BYTE Index
Range 0-2, 0=P, 1=I, 2=D
Fc9-comp-macro.png SetEthernetPort
Configures the Ethernet Port number. Default 1245.
Default 1245
Fc9-comp-macro.png SetEthernetIP
Configures the Ethernet IP Address.
Fc9-string-icon.png - STRING IP
IP Address string e.g. "192.168.1.100"
Fc9-comp-macro.png SetCANID
Stores the specified CAN ID into an internal none volatile memory location.
Fc9-u16-icon.png - UINT ID
Fc9-comp-macro.png GetFeedback
Gets the feedback as a value in real world units
Fc9-comp-macro.png GetAPI
Gets the API version number
Fc9-comp-macro.png SetManualDuty
Sets duty parameter for one of the manual controlled outputs
Range: 0-1
Fc9-f32-icon.png - FLOAT Duty
Duty Cycle Output in Percentage Range 0 - 100%
Fc9-comp-macro.png CheckErrorStatus
Returns the Error status value indicating if there has been any errors. 0 = No Error 1 = Timeout Error
Fc9-comp-macro.png SetCANMode
Configures if the CAN API mde is enabled or disabled.
0=Disabled / 1=Enabled
Range: 0-1
Fc9-comp-macro.png SetLogDivider
Configures the rate of the PID logging.
Fc9-u8-icon.png - BYTE Divider
Divides the rate by the selected value
Fc9-comp-macro.png ZeroSensor
Zeros the attached sensor reading. Useful for Pressure and Level control applications.
Fc9-comp-macro.png SetAutoPIDParam
Sets one of the P, I, D parameters for the Auto on-board PID
Range: 0-5 Where 0=P, 1=I, 2=D, 3=IntClamp, 4=DFilt, 5=FiltCo
Range: 0.0 to 65.535
Fc9-comp-macro.png SetEthernetMode
Configures the Ethernet mode.
0=Disabled, 1=Enabled
Fc9-comp-macro.png SetBluetoothMode
Configures the Bluetooth mode.
Fc9-bool-icon.png - BOOL Mode
Fc9-comp-macro.png Initialise
Fc9-comp-macro.png SetFeedbackMethod
Sets feedback method to dictate which control application we are running
Fc9-u8-icon.png - BYTE FBMethod
Range: 0-3 Where 0=Level, 1=Flow, 2=Pressure, 3=Temp
Fc9-f32-icon.png - FLOAT InputScaler
Feedback scaling factor used to convert the feedback reading into a meaningful value
Fc9-f32-icon.png - FLOAT OutputScaler
Value used to convert input to 0-100% duty
Fc9-comp-macro.png SetSetpoint
Sets Setpoint parameter for the Auto on-board PID
Fc9-f32-icon.png - FLOAT Setpoint
Required Output in Real World Units
Fc9-type-16-icon.png Comms Method
Selects the method to communicate with the Matrix 3 Axis Robot Arm. USB connection requires the USB drivers to be installed. Bluetooth connection requires the device first be paired using the Windows Bluetooth control panel. WIFI connection requires the connection settings to be configured first on the robot using USB or Bluetooth. CAN connection does not simulate and works on embedded hardware e.g. the MIAC.
Fc9-conn-icon.png COM Port Settings
Fc9-type-7-icon.png Autodetect
Autodetects the COM port, only works for USB AllCode connection.
Fc9-type-16-icon.png COM Port
Selects which port to communicate with, only lists ports which are currently available.
Fc9-type-1-icon.png Text Colour
