Component: Keypad (Numeric 3x4) (Keypad)
Jump to navigationJump to searchAuthor | Matrix Ltd |
Version | 1.0 |
Category | Keypad |
Keypad (Numeric 3x4) component
Preset keypad based around the 3 * 4 unit, as used by the Matrix EB014 E-block
Please click here for the component source code: FC_Comp_Source_Keypad_Numeric.fcfx
Basic Example
Keypad Example File demonstrating controlling a door lock.
LED is used to show the pin status controlling the door lock.
WaitPressed |
Blocking call that waits for one of the keys on the keypad to be pressed. The index of the key that was pressed is passed back to the user. | |
Return |
GetAscii |
Gets the ASCII value for the current keypress. If no key is pressed then the macro returns the value 255. | |
Return |
GetString |
Gets the ASCII value for the current keypress and returns in the form of a string. If no key pressed then the macro returns a null string. | |
Return |
GetNumber |
Gets the numeric value for the current keypress. If no key pressed then the macro returns the value 255. | |
Return |
GetIndex |
Gets the index value for the current keypress. If no key pressed then the macro returns the value 255. | |
Return |
WaitReleased |
Blocking call that waits for the keys on the keypad to be released. If no key is pressed then the function will return immediatley. | |
Return |
