| Version | 2.0 |
| Category | LEDs |
RGB LED APA102C component
A simple chained RGB LED controller IC allowing multiple LEDs to be controlled using a serial data stream. Allows RGB LEDs to be driven with full 24-bit colour depth. Allows single chains, 2D arrays and 3D cube formations to be simulated. Supports Bit Banged or SPI peripheral based data modes.
Please click here for the component source code: FC_Comp_Source_LED_APA102C.fcfx
|   | SetBrightness |
| Allows the output colour brightness of the LEDs to be scaled down. For example to save current usage or to reduce brightness in dark environments. |
|  - FLOAT | Scaler |
| Range: 0.0 to 1.0 Default: 1.0, 0 = Off, 0.5 = Half Brightness, 1.0 = Full Brightness |
|  - VOID | Return |
|   | GetLEDColour |
| Sets the colour of a single LED in RAM as a 1D array. |
|  - UINT | LED |
| LED to change the colour / Range: 0 to (LED Count - 1) |
|  - BYTE | ColIdx |
| 0 = R, 1 = G, 2 = B |
|  - BYTE | Return |
|   | SetBrightnessByte |
|  - BYTE | Scaler |
| Range: 0 to 255 Default: 255, 0 = Off, 128 = Half Brightness, 255 = Full Brightness |
|  - VOID | Return |
|   | DrawLine2D |
| Draws a line on a 2D array of LEDs |
|  - UINT | X1 |
|  - UINT | Y1 |
|  - UINT | X2 |
|  - UINT | Y2 |
|  - BYTE | R |
|  - BYTE | G |
|  - BYTE | B |
|  - VOID | Return |
|   | SetLEDColour |
|  - UINT | LED |
|  - BYTE | R |
|  - BYTE | G |
|  - BYTE | B |
|  - VOID | Return |
|   | SetAllLEDColour |
| Sets the colour of all the LEDs in RAM |
|  - BYTE | R |
|  - BYTE | G |
|  - BYTE | B |
|  - VOID | Return |
|   | Refresh |
| Clocks out the current colour data to the LEDs from the values stored in RAM |
|  - VOID | Return |
|   | ShiftLEDs1D |
| Shifts the LED colours in 1D and wraps |
|  - BYTE | Direction |
| 0 = Forwards, 1 = Backwards |
|  - BYTE | DataMode |
| 0=ResetToZero, 1=WrapAroundDisplay, 2=Smear |
|  - VOID | Return |
|   | DrawLine3D |
| Draws a line on a 3D array of LEDs |
|  - UINT | X1 |
|  - UINT | Y1 |
|  - UINT | Z1 |
|  - UINT | X2 |
|  - UINT | Y2 |
|  - UINT | Z2 |
|  - BYTE | R |
|  - BYTE | G |
|  - BYTE | B |
|  - VOID | Return |
|   | GetLEDIndex2D |
| Sets the index of a single LED in RAM as a 2D array. |
|  - UINT | X |
| LED Column to change the colour / Range: 0 to (LED Column - 1) |
|  - UINT | Y |
| LED Row to change the colour / Range: 0 to (LED Row - 1) |
|  - UINT | Return |
|   | DrawRectangle2D |
| Draws a basic 2D rectangle onto the LEDs |
|  - BYTE | X1 |
|  - BYTE | Y1 |
|  - BYTE | X2 |
|  - BYTE | Y2 |
|  - BYTE | DrawStyle |
| Sets the draw style - 0=Soild, 1=Edge, 2=Corners |
|  - BYTE | R |
|  - BYTE | G |
|  - BYTE | B |
|  - VOID | Return |
|   | ShiftLEDs2D |
| Shifts the contents of the display by the number of vertices specified ***Please Note that Wrap mode is currently unavailable*** |
|  - INT | X |
| Number of pixels to shift the display -1 to 1 / 0 = No Shift |
|  - INT | Y |
|  - BYTE | DataMode |
|  - VOID | Return |
|   | GetLEDIndex3D |
| Gets the index of a single LED in RAM as a 3D array. |
|  - UINT | X |
|  - UINT | Y |
|  - UINT | Z |
| LED Layer to change the colour / Range: 0 to (LED Layer - 1) |
|  - UINT | Return |
|   | DrawCuboid3D |
| Draws a basic 3D cuboid onto the LEDs |
|  - BYTE | X1 |
|  - BYTE | Y1 |
|  - BYTE | Z1 |
|  - BYTE | X2 |
|  - BYTE | Y2 |
|  - BYTE | Z2 |
|  - BYTE | R |
|  - BYTE | G |
|  - BYTE | B |
|  - VOID | Return |
|   | Initialise |
| Inisialises the RGB colour RAM to 0,0,0 = LED Off and clocks out the data to  initialise all the WS2801 ICs in the chain. |
|  - VOID | Return |
|   | ShiftLEDs3D |
|  - INT | X |
|  - INT | Y |
|  - INT | Z |
|  - BYTE | DataMode |
|  - VOID | Return |
|   | Properties |
|   | LED Properties |
|   | LED Arrangement |
| Controls the arrangement of the LEDs on the panel.  1D - Creates a straight line of LEDs 2D - Creates an X by Y Array of LEDs 3D - Creates an X by Y by Z Array of LEDs |
|   | LED Count |
| Total number of LEDs in the design |
|   | Column Spacing |
| X Spacing Between LEDs on the Panel |
|   | LED Current Usage |
|   | Connections |
|   | Output Mode |
| Sets the output mode used to drive the data to the LEDs Bit Banged Mode = Allows Any I/O Pin but may be slower SPI Mode = Fixed SPI Peripheral Pins but may be faster - Note that the SPI MISO pin will not be available for general I/O |
|   | Connection Properties |
|   | Channel |
| SPI Channel selector |
|   | Prescale |
| Prescale option selector |
|   | MOSI |
| SPI Data Out Pin SDO - Also Known as Master Out Slave In (MOSI) when used in Master mode. |
|   | MISO |
| SPI Data In Pin SDI - Also Known as Master In Slave Out (MISO) when used in Master mode. |
|   | CLK |
| SPI Clock Pin CLK - The Clock signal is driven by the SPI master. |
|   | Simulation |
|   | Scope Traces |
| Selects if the scope traces are automatically generated or not |
|   | Console Data |
| Selects if the console data is automatically generated or not |
|   | API |
