Component: SCADA (UART Dummy) (SCADA Slaves)
| Category | SCADA Slaves |
SCADA (UART Dummy) component
Dummy SCADA Slave component to enable injector referencing. Supports: Digital IO / UART See Flowcode Help Wiki for firmware.
Please click here for the component source code: FC_Comp_Source_OLD_API_Slave_UART_Dummy.fcfx
|   | IOGetInputPin |
|  - BYTE | Pin |
| Range: 0-13 | |
|  - BOOL | Return |
|   | UARTBaud |
|  - BYTE | Rate |
|  - VOID | Return |
|   | UARTCheckRX |
|  - BYTE | Return |
|   | UARTInitialise |
|  - VOID | Return |
|   | IOSetOutputPin |
|  - BYTE | Pin |
| Range: 0-13 | |
|  - BOOL | State |
| Range: 0-1 | |
|  - VOID | Return |
|   | UARTReceive |
|  - BYTE | Return |
|   | UARTSend |
|  - BYTE | Data |
|  - VOID | Return |
|   | Initialise |
|  - VOID | Return |
|   | Properties |
