Component: PIR Motion (Grove 101020020) (101020020) (Light)
Revision as of 14:42, 16 January 2023 by Wiki bot (talk | contribs)
Category Light
PIR Motion (Grove 101020020) component
PIR motion sensor component for digital output sensors. Simulates range sensitivity and output hold.
Please click here for the component source code: FC_Comp_Source_PIR_Motion_Sensor.fcfx
SampleSensor
Returns the state of the sensor. Activated if movement detected in the sensor range.
Configures the I/O ready for the sensor to be sampled.
SIG Pin
Pin connected to the sensor element of the photo transistor
Sim Mode
Panel Settings
Sensitivity
Simulation range used to detect object
Holding Count
Number of calls to SampleSensor to repeat active state, once triggered
