Component: Potentiometer (Analog Input)
Revision as of 09:13, 16 January 2023 by MartinW (talk | contribs) (Examples)
Category Analog Input
Potentiometer component
Please click here for the component source code: FC_Comp_Source_Potentiometer.fcfx
Potentiometer Example
ReadAsInt
Read the ADC at full bit depth
- INT Return
GetValue
Get the Float value, between lower and upper bounds. Used on App Developer
- FLOAT Return
ReadAsFloat
Reads the ADC as a direct voltage
- FLOAT Return
SetValue
Sets the Float value, between lower and upper bounds. Used on App Developer
- FLOAT Value
ReadAsVoltage
- FLOAT Return
ReadAsByte
Read the ADC as a byte
Settings
VRef voltage
VRef option
Conversion speed
Acquisition cycles
Bit Depth
Component Label
User Label Text
Text to display
Scale Range
Show Connection Label
Show Pin Value
Colour Style
Style
Type
Scale
Lower Bound
Upper Bound
Major Tick Step
Minor Tick Step
Label Format
Closed
Start Angle
End Angle
