Component: Barometer (DPS310) (Environmental)
Revision as of 14:42, 16 January 2023 by Wiki bot (talk | contribs)
Category Environmental
Barometer (DPS310) component
A barometric air pressure sensor with high accuracy and low current consumption. Capable of sensing air pressure and temperature. Based on an I2C bus connection.
Please click here for the component source code: FC_Comp_Source_Pressure_Sensor_DPS310.fcfx
Fc9-comp-macro.png ReadTemperature
Reads the temperature measurement from the last SampleSensor macro
Fc9-comp-macro.png ConfigurePressure
Configures the pressure sensor sample rate and over sampling count
Fc9-u8-icon.png - BYTE Rate
Range: 0-7, 0=1Hz, 1=2Hz, 2=4Hz etc
Fc9-u8-icon.png - BYTE Oversample
Range: 0-7, 0=1Samples, 1=2Samples, 2=4Samples etc
Fc9-comp-macro.png ConfigureTemperature
Configures the temperature sensor sample rate and over sampling count
Fc9-comp-macro.png ReadPressure
Reads the pressure measurement from the last SampleSensor macro
Fc9-comp-macro.png SetMode
Sets the operational mode of the sensor to be continous or one shot
Fc9-u8-icon.png - BYTE Mode
Fc9-comp-macro.png ReadAltitude
Reads the pressure measurement from the last SampleSensor macro and converts the pressure reading into an altitude reading.
Fc9-comp-macro.png SampleSensor
Checks to see if new data is available for temperature or pressure and collects it. Returns 0 if no new data is available Returns 1 for pressure, 2 for temperature and 3 for both.
Fc9-comp-macro.png ReadRegister
Reads a byte from a register
Fc9-comp-macro.png WriteRegister
Writes a byte to a register
Fc9-u8-icon.png - BYTE Data
Fc9-comp-macro.png Initialise
Starts up the I2C ready to communicate with the sensor. Sets the selected rates and operational mode. Returns 1 if the sensor has been found and initialised.
Fc9-conn-icon.png Device Settings
Fc9-type-16-icon.png Device Address
Fc9-type-16-icon.png Measurement Rate
Fc9-type-16-icon.png Oversample Rate
Fc9-type-16-icon.png Operational Mode
Fc9-type-16-icon.png Channel
Channel selection
Baud rate to be used
Fc9-type-5-icon.png SDA
Fc9-type-5-icon.png SCL
Fc9-conn-icon.png Simulation
No: Provides simulation using the panel component sliders. Yes: Communicates via an API Slave device to real world hardware, shows the results using the panel component sliders.
