Component: Robot Arm v2 (AllCode)
Revision as of 14:42, 16 January 2023 by Wiki bot (talk | contribs)
Category AllCode
Robot Arm v2 component
Drives the Matrix Robot Arm v2 hardware via the AllCode API. Allows connections via USB, Bluetooth and WIFI.
Please click here for the component source code: FC_Comp_Source_RA2_ComponentSource.fcsx
SetWIFIPort
Sets the WIFI port number
- UINT Port
Default 1245
WhileMoving
Blocking call that waits up to 10 seconds for the current movement operation to complete. Returns when complete. Return of 1 indicates movement complete, 0 indicates timeout.
- BOOL Return
SetWIFIPassword
Configures the WIFI Password string and stores into the none volatie memory onboard the robot arm. Call the SetWifiMode macro after this to action the change.
- STRING Password
Password String, Max 32 Characters
SetCalibrationLengths
Sets the lengths of parameters A and D used as part of the kinematics calculations to get and set the angles using XYZ coordinates
- FLOAT LengthA
- FLOAT LengthD
SetMovementSpeed
Controls the movement speed of the arm and the ramping increment
- UINT Speed
Range 0-10000 default 8000
- UINT Increment
Range 0 to 5000, default 50
GetPLCInputs
Reads the inputs on the secondary grove connector used to connect to outputs from a connected PLC or other external switch.
SetGripper
Sets the new position of the gripper
- BYTE Position
0 = Closed, 255 = Fully Open
SetCalibrationPosition
Called when the arm gripper is in the calibration position of X0 Y300 Z5 Reconfigures the kinematics calculations based on this. Performed in factory to calibrate the arm, warning calling this function will effect factory calibration.
StoreAngles
Stores the specified joint angles into an internal none volatile memory location.
- BYTE PositionIndex
Range: 0 to 40
- FLOAT AngleA
Range 0.0 to 359.0
- FLOAT AngleB
Range 0.0 to 359.0
- FLOAT AngleC
Range 0.0 to 359.0
GetWifiIP
Collects the IP address of the robot arm WIFI connection.
- STRING Return
GetColourSensor
Samples and returns the RGB values read by the colour sensor
- BYTE RGB
Byte Array To Hold the RGB sensor values
SetMotor
Sets the step position of a single motor
- BYTE Motor
0=A, 1=B, 2=C
- UINT Position
ResetToBoot
Resets the board into bootload mode for reprogramming. Comms port will be closed on calling this macro,
IsMoving
Checks to see if the robot arm or gripper is moving. Returns 0 if the arm is not moving and 1 if the arm is still in transit.
- BOOL Return
SetAngle
Sets the angle of a single motor
- BYTE Motor
0=A, 1=B, 2=C
- FLOAT Angle
Range 0.0 to 359.0
SetXYZ
Moves the machine so that the end tool is in the specified XYZ position. Returns 1 if the coordinates are within range of the Arm else returns 0.
- INT X
- INT Y
- INT Z
- BOOL Return
SetBluetoothPin
Configures the Bluetooth pin and stores into the none volatie memory onboard the robot arm. Call the SetBluetoothMode macro after this to action the change.
- STRING Pin
Pin String, 4 Numeric Characters e.g. "1234"
HomeAll
Function to automatically home all motors. Macro blocks until complete.
SetRelay
Allows the vacuum relay to be switched on and off.
- BOOL State
SetCalibrationRadius
- FLOAT Radius
SetAngles
Sets the angle of all motors
- FLOAT AngleA
Range 0.0 to 359.0
- FLOAT AngleB
Range 0.0 to 359.0
- FLOAT AngleC
Range 0.0 to 359.0
GotoPosition
Recalls a position from the selected internal none volatile memory location. Performs linear interpolated movement to the selected position.
Range: 0 to 40
SetWifiMode
Configures the WIFI mode. When enabled the robot arm can either create its own WIFI network or join an existing WIFI network,
- BYTE Mode
0=Disabled, 1=Host Network, 2=Join Network
HomeAxis
Function to automatically home a specific motor. Macro blocks until complete.
- BYTE Axis
0=A, 1=B, 2=C
GetAngles
Collects the current joint angles of the motors.
- FLOAT Angles
Float Array To Hold the step position return values
DisableMotors
Disables all motors
StoreMotors
Stores the specified step position into an internal none volatile memory location.
Range: 0 to 40
- UINT PositionA
- UINT PositionB
- UINT PositionC
SetCanId
Stores the specified CAN ID into an internal none volatile memory location.
- UINT ID
GetAPI
Gets the API version number
SetMotors
Sets the step position of all motors
- UINT PositionA
- UINT PositionB
- UINT PositionC
SetCanMode
Configures the CAN mode.
- BOOL Mode
0=Disabled, 1=Enabled
SetWifiSSID
Configures the WIFI SSID string and stores into the none volatie memory onboard the robot arm. Call the SetWifiMode macro after this to action the change.
- STRING SSID
Netword ID String, Max 32 Characters
GetPosition
Collects the current step positions of the motors.
- UINT Positions
UINT Array To Hold the step position return values
StoreCurrentPosition
Stores the current position into an internal none volatile memory location.
Range: 0 to 40
GetXYZ
Collects the current XYZ position of the end tool.
- INT XYZ
INT Array To Hold the X, Y and Z return values
SetBluetoothMode
Configures the Bluetooth mode.
- BOOL Mode
- BOOL Return
SetBluetoothName
Configures the Bluetooth device name and stores into the none volatie memory onboard the robot arm. Call the SetBluetoothMode macro after this to action the change.
- STRING Name
Bluetooth Device String, Max 20 Characters
Simulation Mode
API Settings
Comms Method
Selects the method to communicate with the Matrix 3 Axis Robot Arm. USB connection requires the USB drivers to be installed. Bluetooth connection requires the device first be paired using the Windows Bluetooth control panel. WIFI connection requires the connection settings to be configured first on the robot using USB or Bluetooth. CAN connection does not simulate and works on embedded hardware e.g. the MIAC.
COM Port Settings
Autodetect
Autodetects the COM port, only works for USB AllCode connection.
