Component: Servo Motor (Mechatronics)
Revision as of 14:42, 16 January 2023 by Wiki bot (talk | contribs)
Version 1.1
Category Mechatronics
Servo Motor component
Base component for creating custom servo motor simulations. Recieves messages from the the 'Servo Controller' component. Macro 'SetTarget' allows external objects to be moved by the servo for mechanical simulations.
Please click here for the component source code: FC_Comp_Source_Servo_Motor_2d.fcfx
Fc9-comp-macro.png GetSimAngle
Gets the angle of the simulated motor shaft in degrees.
Fc9-type-16-icon.png Movement Type
Fc9-type-15-icon.png Minimum (degrees)
Angle that the servo turns when the PWM signal is at its minimum. Measured from the actuator object's 'rest' position, chosen at the time of connecting the object.
Fc9-type-15-icon.png Maximum (degrees)
Angle that the servo turns when the PWM signal is at its maximum. Measured from the actuator object's 'rest' position, chosen at the time of connecting the object.
