Component: Stepper Motor Template (Mechatronics)
Jump to navigationJump to searchAuthor | Matrix Ltd |
Version | 1.2 |
Category | Mechatronics |
Stepper Motor Template component
Enables the creation of a stepper motor component by specifying objects for its appearance. 'Attach to...' property should be exposed in any components buit from this - this sets a target object to be joined to the motor shaft. The target can then be rotated around the axis with a custom gear ration, or moved linearly according to the pitch of a given lead screw.
Please click here for the component source code: FC_Comp_Source_Stepper_Motor_Base.fcfx
IncrementStep |
Move the motor forward by one step. | |
Return |
DecrementStep |
Move the motor backwards by one step. | |
Return |
EnableMotor |
Turn on the motor. This must be done before it will respond to any other macros. | |
Return |
DisableMotor |
Turn off the motor. It will no longer respond to any other macros. | |
Return |
