Component: TCP/IP Dummy (ENC28J60) (Comms: Networking)
Revision as of 14:43, 16 January 2023 by Wiki bot (talk | contribs)
Version 2.0
Category Comms: Networking
TCP/IP Dummy component
A set of routines used to control a ENC28J60 TCP/IP Module. Required connections VCC, Reset, GND, SCK, MISO, MOSI, CS. Leave these pins disconnected CLKOUT, ENC_WOL, ENC_INT
Please click here for the component source code: FC_Comp_Source_TCPIP_ENC28J60_Dummy.fcfx
Here is a simple example to help get started with the ENC28J60 module.
The example program creates a web page server on the network and will also respond to ping requests.
The HTML to drive the web pages is included in the flowchart near the bottom of the main program loop. ENC28J60 Example
PacketSend
Attempts to transmit a data packet to the ENC28J60 module.
- UINT Length
MakeTcpSynackFromSyn
- UINT Port
MakeArpRequest
[[File:]] - ServerIP
InitialiseDataLengthInfo
Initialises the data pointers to allow us to craft a response containing data
MakeTcpAckFromAny
- UINT Port
PacketReceive
Attempts to receive a data packet from the ENC28J60 module. Returns the number of bytes received.
CheckForTCPType
Checks to what kind of TCP type the received data is requesting. Returns a bit field specifying the type of request. 0x01 = Ack Requires, 0x02 = Synchronise 0x10 = Ack
CheckArpPacketIsMyreplyArp
CheckForIp
Checks to see if the received data is an IP request with my IP address.
- UINT Length
CheckForTCPPort
Checks to see if the received data is requesting the server port
- UINT Port
CheckForPing
Checks to see if the received data is a Ping request
GetModuleRevision
Requets the module revision number and returns the value supplied by the module's firmware.
MakeTcpAckWithData
- UINT DataLength
MakeArpAnswerFromRequest
ReadRegister
Reads the value from a single register onboard the ENC28J60 module.
- BYTE Address
CheckForARP
Checks to see if the received data is an ARP request with my IP address.
- UINT Length
ClientSendPacket
- UINT DestPort
- UINT SourcePort
- BYTE Flags
- BYTE MaxSegmentSize
- BYTE ClearSeqAck
- UINT NextAckNum
- UINT DataLength
- BYTE DestMac
- BYTE DestIp
MakeEchoReplyFromRequest
- UINT Length
ControlLEDs
Allows both the LEDs on the Ethernet socket to be controlled. Useful for checking if the SPI communications are functioning correctly.
- BYTE Mode
0=Off, 1=On, 2=Auto
GetDataLength
Returns the number of received data bytes after the headers
GetTcpDataPointer
WriteRegister
Writes a value to a single register onboard the ENC28J60 module.
- BYTE Address
- BYTE Data
FillTcpData
- UINT Position
- STRING Data
ReadStringFromBuffer
Reads a string from the buffer at location specified for the number of bytes specified. If a space character is encountered then the macro will return straight away without the space character in the string.
- UINT BufferLocation
- BYTE NumberOfBytes
Number of bytes to read from the buffer and store into string
- STRING Return
GetSendersMAC
Gets the MAC address from locations 6-11 of the IP Header
- BYTE MAC
6-byte Array to store the MAC address
FillTcpArray
- UINT Position
- UINT Count
- BYTE Data
Initialises the SPI connection to the TCPIP module and sets up some initial values. Flashes the LEDs on and off twice to confirm SPI comms are active. LEDs are then configured to auto functionality.
