Component: Button helper (Helpers)
Revision as of 14:43, 16 January 2023 by Wiki bot (talk | contribs)
Version 1.1
Category Helpers
Button helper component
A button overlay that allows any object to behave like a button
Please click here for the component source code: FC_Comp_Source_buttonhelper.fcfx
GetStateFor
Returns true if the button is depressed, else false
- HANDLE Target
- BOOL Return
Clear
Clears all objects from the lists This leaves no links for the button helper
SetDisabledPos
Sets the position of the released button
- HANDLE PositionHandle
A handle to the position of the depressed location
SetEnabledPos
Sets the position of the depressed button
SetAxis
Sets the movement axis as an Axis_... constant
- BYTE Axis
Movement axis to set to, default 4
SetDisabledPosFor
Sets the disabled position for an object
- HANDLE Target
- HANDLE Position
GetTarget
Gets the target handle the property links to
- HANDLE Return
GetState
- BOOL Return
Register
Adds the object to the list if not already there
- HANDLE Target
SetNotify
Sets the object to notify when the button is pressed or released
- HANDLE Handle
The handle of the object - 0 to use the caller object
- ULONG Ident
The identifier to send in the System.Notify message
SetLatchingFor
Sets whether the button is depressed when the mouse is released
- HANDLE Target
- BOOL Enabled
SetMode
Sets the animation mode for the button
- BYTE Mode
0=User, 1=Up/Down, 2 = Lever
SetEnabledPosFor
Sets the enabled position for an object
- HANDLE Target
- HANDLE Position
SetPivotPosFor
Sets the position the lever rotates around for an object
- HANDLE Target
- HANDLE Position
SetModeFor
- HANDLE Target
The target object, 0 for 'set default'
- BYTE Mode
SetMovement
Sets the movement in units or PI/16 steps for the button
- FLOAT Move
Movement to set to - default is 4
SetAxisFor
- HANDLE Target
- BYTE Axis
SetPivotPos
Sets the position of the object the lever rotates around
SetAutoReset
Sets the state of the auto-reset flag If the flag is true (it is by default) then Button Helper will reset the state of each button on stop
- BOOL State
Set true to reset to off on sim stop, else false to retain state
SetLatching
- BOOL Enabled
Unregister
Removes the object to the list if present
- HANDLE Target
SetMovementFor
- HANDLE Target
- FLOAT Move
Movement to set to, default 4
Host component
Lever pivot
