Component: GLCD (EBM001) (EBM Modules)
Revision as of 14:40, 16 January 2023 by Wiki bot (talk | contribs)
Version 1.6
Category EBM Modules
GLCD (EBM001) component
Graphical display component designed to work with the EBM001 modules and EB084 E-blocks. Based on the ILI9163C 16-bit colour graphical controller IC.
Please click here for the component source code: FC_Comp_Source_GLCD_EBM001.fcfx
EBM001 Basic Example
EBM001 gLCD Example File FC6 Icon.png EBM001 Example Example should show the following on the display on the panel and on the hardware.
EBM001 Maze Builder
FC6 Icon.png Maze Builder gLCD Example to draw a randomly generated 2D maze on an EBM001 graphical display.
FC6 Icon.png 3D Manipulations Example should show the following on the display on the panel and on the hardware. The two switches allow you to move closer to or away from the object. The perspective provides more and more distortion to the object the closer you get.
Fc9-u8-icon.png - BYTE Font
Fc9-comp-macro.png BacklightOn
Sets the backlight enable pin allowing the display backlight to switch on. Switching the backlight on and off at high speed allow the light to be dimmed.
Fc9-u8-icon.png - BYTE ScaleX
Fc9-u8-icon.png - BYTE ScaleY
Fc9-s16-icon.png - INT Number
Fc9-u16-icon.png - UINT X
Fc9-u16-icon.png - UINT Y
Fc9-comp-macro.png DrawLine
Fc9-u16-icon.png - UINT X1
Fc9-u16-icon.png - UINT Y1
Fc9-u16-icon.png - UINT X2
Fc9-u16-icon.png - UINT Y2
Fc9-comp-macro.png Plot
Fc9-u8-icon.png - BYTE Solid
Fc9-comp-macro.png FastPlot
Fc9-comp-macro.png BacklightOff
Clears the backlight enable pin allowing the display backlight to switch off. Switching the backlight on and off at high speed allow the light to be dimmed.
Fc9-comp-macro.png BPlot
Fc9-comp-macro.png Window
Specifies a full screen or sub window of pixels to draw. Useful when used with the FastPlot function to draw bitmaps at high speed.
Fc9-u8-icon.png - BYTE Index
0=SpaceWidth, 1=PixelHeight
Fc9-u8-icon.png - BYTE Red
Fc9-u8-icon.png - BYTE Green
Fc9-u8-icon.png - BYTE Blue
Fc9-comp-macro.png DrawCircle
Fc9-comp-macro.png Initialise
Fc9-conn-icon.png Dimensions
Fc9-conn-icon.png Colour
Fc9-conn-icon.png Bit Depth
Fc9-type-14-icon.png Colour Bit Depth
Fc9-type-5-icon.png Data
Data pin connection
Fc9-type-5-icon.png Clock
Clock pin connection
Fc9-type-5-icon.png Chip Select
Chip select pin connection
Fc9-type-5-icon.png A0
Fc9-type-5-icon.png Reset
Reset pin connection
Fc9-type-5-icon.png LED
Fc9-conn-icon.png Fonts
Fc9-conn-icon.png Font 0
Fc9-conn-icon.png Simulation
Fc9-type-15-icon.png Component Label Scale
Fc9-type-16-icon.png Physical Orientation
