Component: GLCD (ST7565R) Parallel (Graphical Monochrome)
Revision as of 14:40, 16 January 2023 by Wiki bot (talk | contribs)
Version 1.5
Category Graphical Monochrome
GLCD (ST7565R) Parallel component
Graphical display component designed to work with the ST7565 type monochrome displays. Transfers data using an 8-bit digital data bus.
Please click here for the component source code: FC_Comp_Source_GLCD_ST7565R.fcfx
ReadFontWidth
- BYTE Font
- BYTE Character
SetFontScaler
- BYTE ScaleX
- BYTE ScaleY
- INT Number
- UINT X
- UINT Y
- BYTE Font
- BYTE Transparent
DrawLine
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
DrawEllipse
- UINT X
- UINT Y
- UINT XRadius
- UINT YRadius
- BYTE Transparent
- BYTE Solid
Plot
- UINT X1
- UINT Y1
SetDisplayOrientation
- BYTE Orientation
BPlot
- UINT X1
- UINT Y1
ReadFontStat
- BYTE Font
- BYTE Index
0=SpaceWidth, 1=PixelHeight
Print
- STRING Str
- UINT X1
- UINT Y1
- BYTE Font
- BYTE Transparent
ClearDisplay
SetBackgroundColour
- BYTE PixelColour
0=White, 1=Black
DrawCircle
- UINT X
- UINT Y
- UINT Radius
- BYTE Transparent
- BYTE Solid
SetForegroundColour
- BYTE PixelColour
0=White, 1=Black
DrawRectangle
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
- BYTE Transparent
- BYTE Solid
Dimensions
Pixel Width
Pixel Height
Colour
Monochrome
Foreground Color
Background Color
Bit Depth
Color Bit Depth
Red Bit Depth
Green Bit Depth
Blue Bit Depth
Data Pins
Decides if the 8-bit data bus is controlled using a full port or individual pins. A full port will run faster whereas individual pins allow for more flexibility.
DATAPORT
CS1
Chip select pin
RES
Reset pin
A0
RD_E
Enable pin used to clock data into the display
WR_RW
Read Write pin to set the display data mode
MODE
Fonts
Font Count
Font 0
Font
Character Spacing
Space Width
Simulation Mode
Physical Orientation
