Component: LED (5mm, Panel) ()
Revision as of 14:43, 16 January 2023 by Wiki bot (talk | contribs)
Version 1.1
Category
LED (5mm, Panel) component
Standard 5mm LED mounted in a panel clip. Colour can be changed in component properties.
Please click here for the component source code: FC_Comp_Source_led_5mm_pnl.fcfx
LED Resistor Calculator Tool
Fc9-type-5-icon.png Connection
The pin to which the LED is connected.
Fc9-type-16-icon.png Polarity
Active High: Pin true -> On color, Pin false -> Off color Active Low: Pin true -> Off color, Pin false -> On color.
Fc9-conn-icon.png Simulation
Fc9-type-1-icon.png Color
LED color when it is turned on. When turned off, it will use a darker shade of the same hue.
Fc9-conn-icon.png Label
Fc9-type-16-icon.png Show
Decide what labels to show... None - no labels are displayed Name - shows each component's name Property - shows a particular property of each component (see 'property' below.
Fc9-type-10-icon.png Property
Show a particular property of each object. If a port or pin property is chosen, the label can be abbreviated to remove the '$PORT' text.
Color of the labels text.
Fc9-type-15-icon.png Scale
Sets the basic size (text height) of the labels.
Fc9-type-7-icon.png Follow Zoom
Whether labels get bigger and smaller when the panel is zoomed in and out.
Fc9-type-16-icon.png Position
Position of the label relative to the component
