Component: LED Free (SMD, PCB) ()
Author | Matrix Ltd |
Version | 1.1 |
Category |
LED Free (SMD, PCB) component
Surface mount LED in standard PLCC2 package. Colour can be set friom component properties.
Please click here for the component source code: FC_Comp_Source_led_plcc2_free.fcfx
