Component: Potentiometer (Panel) ()
Version 1.4
Category
Potentiometer (Panel) component
Analogue potentiometer with chicken head style pointer.
Note: The default Vref properties for AVR/Arduino is AREF. If there is no voltage being applied to the AREF pin, then you must change Vref option from AREF to AVCC
Please click here for the component source code: FC_Comp_Source_pot_Panel.fcfx
Potentiometer Example
Start Angle
Sweep Angle
Retain Value
If yes is slected After saving your project, the ADC value will be retained when your project is reloaded.
Settings
VRef voltage
VRef option
Conversion speed
Acquisition cycles
Bit Depth
