Component: Potentiometer (Panel) ()
Revision as of 14:43, 16 January 2023 by Wiki bot (talk | contribs)
Version 1.4
Category
Potentiometer (Panel) component
Analogue potentiometer with chicken head style pointer.
Please click here for the component source code: FC_Comp_Source_pot_Panel.fcfx
FC6 Icon.png Potentiometer Example
Fc9-conn-icon.png Simulation
Fc9-type-15-icon.png Start Angle
Fc9-type-15-icon.png Sweep Angle
Fc9-type-7-icon.png Retain Value
If yes is slected After saving your project, the ADC value will be retained when your project is reloaded.
Fc9-type-6-icon.png Channel
Fc9-conn-icon.png Settings
