Component: LED Mono (LED)
Revision as of 08:48, 16 January 2023 by MartinW (talk | contribs) (→‎Examples)
Category LED
LED Mono component
Please click here for the component source code: FC_Comp_Source_LED_Mono_2dgi.fcfx
Here is an example Flowcode program to read the value of a switch and change the state of LED accordingly. FC6 Icon.png LED Example
LED Resistor Calculator Tool
Fc9-comp-macro.png TurnOn
Fc9-comp-macro.png SetState
Sets the state of the LED, accounting for the polarity.
Fc9-bool-icon.png - BOOL State
1=On, 0=Off
Fc9-comp-macro.png TurnOff
Fc9-conn-icon.png LED Settings
Fc9-type-5-icon.png Connection
Fc9-type-16-icon.png Polarity
Fc9-conn-icon.png Label
Fc9-type-16-icon.png Component label position
Fc9-type-2-icon.png Label Colour
Fc9-type-7-icon.png Show Connection Label
If enabled, the pin designation will be shown, e.g. B0.
Fc9-type-7-icon.png Show Pin Value
Pin status of VCC or GND will be shown when enabled and simualtion is running.
Fc9-type-16-icon.png Pin label position
Fc9-conn-icon.png Appearance
Fc9-type-16-icon.png Shape
Fc9-type-16-icon.png Colour
Fc9-type-16-icon.png Style
