Component: Switch Slide (Switch)
Revision as of 08:57, 16 January 2023 by MartinW (talk | contribs) (→‎Examples)
Author MatrixTSL
Category Switch
Switch Slide component
A simple digital push switch allowing latched and none latched operation. In embedded mode displays the connecting pin and pin status.
Please click here for the component source code: FC_Comp_Source_Switch_Slide_2dgi.fcfx
Here is an example Flowcode program to read the value of a switch. FC6 Icon.png Switch Slide Example
(5V / 11K) * 10K = 4.54545V
Fc9-comp-macro.png ReadState
Reads the button state as 0 for released or 1 for pressed Performs debounce if required
Fc9-comp-macro.png WaitUntilHigh
Waits until the switch is in state 'high' The interpretation of 'high' depends on the polarity
Fc9-comp-macro.png SetState
Sets the switch to be on or off.
Fc9-bool-icon.png - BOOL State
The new state of the switch (true=on, false=off)
Fc9-comp-macro.png WaitUntilLow
Waits until the switch is in state 'low' The interpretation of 'high' depends on the polarity
Fc9-conn-icon.png Switch Settings
Fc9-type-5-icon.png Connection
Fc9-type-16-icon.png Polarity
Fc9-type-14-icon.png Debounce
Fc9-type-7-icon.png Latching
Fc9-conn-icon.png Label
Fc9-type-1-icon.png Label Colour
Fc9-type-7-icon.png Show Connection Label
Fc9-type-7-icon.png Show Pin Value
Fc9-conn-icon.png Appearance
Fc9-type-16-icon.png Style
Fc9-type-12-icon.png Type
Fc9-type-10-icon.png On Label
Fc9-type-10-icon.png Off Label
