Event Scope.Overlay
Revision as of 11:09, 10 June 2013 by JonnyW (talk | contribs) (XML Import to change Variable types into Variable Types)
Sent when the mouse hovers over a scope stream
This event is part of the Scope class
HANDLE StreamH
The stream handle
ULONG TimeUS
The -ve offset from now of the time hovered over, in microseconds
FLOAT UnitValue
The value pointed to on the scope, from 0 to 1
STRING Info
The text to display on the overlay
This parameter is returned back to Flowcode
LONG OverlayOffset
The number of micoseconds to add to the Time for the overlay start
ULONG OverlaySize
The number of microseconds of the overlay from its start
ULONG Non-zero to add the overlay to the stream
