Component: 3D Printer (Scenarios)
Jump to navigationJump to search| Author | Matrix Ltd |
| Version | 1.4 |
| Category | Scenarios |
3D Printer component
A simulation only version of a very basic 3D printer such as a standard RepRap.
Please click here for the component source code: FC_Comp_Source_3D_Printer.fcfx
3D Print Using Standard 3D Printer CAD file
A simulated 3D print using an external G code file from an actual 3D printer. The G code file must be placed into the same directory as the Flowcode project to work correctly.
G-Code_Parser
File:Batman.G
3D Maze Generator
A simple 3D maze generator using the 3D printer component to draw the maze.
Maze_Builder_3DP
| ClearPrevPrint | |
| Clears all of the content from any previous print cycles. | |
| MoveByXYZ | |
| Moves the print head by the amount specified in the axis variables using linear interpolation. | |
| X | |
| Y | |
| Z | |
| SetMovementSpeed | |
| Allows the movement speed to be set progmatically. Range 0 - 100 | |
| Speed | |
| Speed control (0 - 100) | |
| MoveToHome | |
| Returns the print head to the start position (0,0,0) | |
| MoveToXYZ | |
| Moves the print head to the specific location specified in the axis variables using linear interpolation. | |
| X | |
| Y | |
| Z | |
| MoveByXYZReal | |
| X | |
| Y | |
| Z | |
| SetMovementSpeedReal | |
| Allows the movement speed to be set progmatically. Range 0.0 - 100.0 | |
| Speed | |
| MoveToXYZReal | |
| X | |
| Y | |
| Z | |
| Sets up the 3D printer component by homing, clearing old print data and assigning the movement speed. | |
