Component: API I2C Dummy (API Slave Devices)
Version | 2.0 |
Category | API Slave Devices |
API I2C Dummy component
API I2C Dummy
Please click here for the component source code: FC_Comp_Source_API_I2C_Dummy.fcfx
I2CInitialise |
Initialsie the I2C module ready for communications | |
Channel |
Channel Index: Range 0 - I2C Bus Count - 1 | |
Baud |
0=100KHz, 1=400KHz, 2=1MHz | |
Return |
I2CRestart |
Put the I2C Module into Restart mode | |
Channel |
Return |
I2CStart |
Put the I2C Module into Start mode | |
Channel |
Return |
I2CReceive |
Receive a byte using the I2C bus | |
Channel |
Last |
Last byte to receive: Range 0-1 | |
Return |
I2CStop |
Put the I2C Module into Stop mode | |
Channel |
Return |
I2CSend |
Transmit a byte using the I2C bus | |
Channel |
DataOut |
Return |
Initialise |
Initialise the comms to the Arduino board ready for commands to be sent. | |
Return |
Properties |
