Component: Ambient Light (BH1750FVI) (Light)
Revision as of 14:09, 20 January 2023 by Wiki bot (talk | contribs)
Category Light
Ambient Light component
A small PCB surface mount ambient light sensor with a I2C bus interface. Spectral responsibility is approximately human eye response. Wide range and High resolution. ( 1 - 65535 lx )
Please click here for the component source code: FC_Comp_Source_AmbientLight_BH1750FVI.fcfx
Fc9-comp-macro.png ContinuousMeasurement
Powers up and starts the continous measurement mode. Delays in between measurements readings must be provided by the user,
Fc9-u8-icon.png - BYTE Resolution
0=1lx (120ms) / 1=0.5lx (120ms) / 2 = 4lx (16ms)
Fc9-comp-macro.png OneTimeMeasurement
Powers up and starts a single measurement before returning to power down mode. Waits for the measurement to be ready and returns the value.
Fc9-comp-macro.png PowerDown
Power Down the Device
Fc9-comp-macro.png ChangeMeasurementTime
Adjusts the measurement result to counteract influence of the optical window.
Fc9-u8-icon.png - BYTE Sensitvity
Range: 31-254 / Default: 69
Fc9-comp-macro.png ReadMeasurement
Reads data from the Light Sensor as a 16-bit value.
Fc9-comp-macro.png ResetMeasurement
Resets the device measurement register, Must be in the powered up state to do this.
Fc9-comp-macro.png Initialise
Stes up the I2C bus and initialises the termperature sensor ready for use.
Fc9-conn-icon.png I2C Properties
Fc9-type-16-icon.png Slave Address
Fc9-type-16-icon.png Channel
Channel selection
Fc9-type-5-icon.png SDA
Fc9-type-5-icon.png SCL
Fc9-type-5-icon.png DVI Pin
Pin used to reset the device.
Baud rate to be used
Fc9-conn-icon.png Simulation
