Component: Control Knob (Controls)
Revision as of 14:10, 20 January 2023 by Wiki bot (talk | contribs)
Version 1.3
Category Controls
Control Knob component
Rotary control designed for SCADA. Has customisable value markings around the control. Simulation only.
Please click here for the component source code: FC_Comp_Source_ControlKnob.fcfx
Fc9-comp-macro.png GetValue
Get the current scale value - this will be the most recent value set using "SetValue", or from the most recent mouse click if the component is in "Control" mode.
Fc9-comp-macro.png SetValue
Set the pointer to the given value on the scale. Returns the angle required to point at the given value.
The value on the scale to move the pointer to.
Fc9-conn-icon.png Range
Fc9-type-15-icon.png Minimum
The minimum value that the knob will output (fully counter_clockwise)
Fc9-type-15-icon.png Maximum
The maximum value that the knob will output (fully clockwise)
Fc9-type-16-icon.png Startup State
Sets the initial value when loading the project or when the runtime starts.
Fc9-type-15-icon.png Default Value
The default value used on initialise or runtime start.
Fc9-conn-icon.png Title
Fc9-type-7-icon.png Show Title
Decides if the component title is shown
Fc9-type-1-icon.png Title Colour
Title Label Color
Fc9-type-10-icon.png Title Text
Title Label Text
Fc9-type-15-icon.png Title Scale
Controls the size of the title text on the panel, default 1.2
Fc9-type-15-icon.png Title Offset
Distance above component center to draw the title
Fc9-conn-icon.png Label
Fc9-type-7-icon.png Show Label
Decides if a label is shown detailing current setting of the control knob.
Fc9-type-1-icon.png Label Colour
Sets the label colour
Fc9-type-10-icon.png Label Units
Adds a unit to the end of the label
Fc9-type-21-icon.png Label Decimal Points
Number of decinal points to draw on the label
Fc9-type-15-icon.png Label Scale
Sets the size of the label on the panel, default 1.0
Fc9-type-15-icon.png Label Offset
Distance above component center to draw the label
Fc9-conn-icon.png Numeric Labels
Fc9-type-14-icon.png Decimals
How many decimal places to show on the number labels.
Fc9-type-14-icon.png Text Size %
Height of the number label text.
Fc9-type-3-icon.png Font
Font for the number labels.
Fc9-type-14-icon.png Divisions
Number of labelled positions around the knob.
Fc9-type-14-icon.png Subdivisions
Number of divisions between the numbered ones.
Fc9-conn-icon.png Scheme
Fc9-type-2-icon.png BG Color
Background colour behind the knob labelling - may be transparent.
Fc9-type-1-icon.png Positive Color
Colour for number labels which are less than zero.
Fc9-type-1-icon.png Negative Color
Colour for number labels which are greater than zero.
Fc9-type-1-icon.png Pointer Colour
Fc9-conn-icon.png Buttons
Fc9-type-7-icon.png Show Buttons
Controls if the adjustment buttons are shown on the scale arc or not.
Fc9-type-1-icon.png Button Color
Color for the component label text.
Fc9-type-15-icon.png Adjustment Value
Sets the button adjustment value, will round the value to the nearest whole adjustment. For example with an adjustment of 1,0 the adjustment buttons will jump to the next whole number.
