Component: DAC Quad (MCP4728) (MCP4728) (Analog Output)
Revision as of 14:10, 20 January 2023 by Wiki bot (talk | contribs)
Category Analog Output
DAC Quad (MCP4728) component
Component to drive a quad digital to analogue converter (DAC) IC from Microchip via an I2C interface. Compatible with MCP4728 (12-Bit) devices.
Please click here for the component source code: FC_Comp_Source_DAC_MCP4728.fcfx
SetOutput
Sets the output voltage of the DAC 12-Bit: Range 0-4095
- BYTE Channel
Range: 0-3 / 0=DAC Channel 0 / 1=DAC Channel 1 ...
- UINT DAC_Value
The value to output to the DAC
ControlPins
Allows Shutdown (SHDN) and Latch (LDAC) pins to be controlled directly if enabled.
- BOOL Latch
0 = Data output driven from DAC register, 1 = Data output locked
SetInitialEEOutput
Stores a DAC value into EE memory to be used on power up.
- BYTE Channel
- UINT DAC_Value
Disable
Disables the DAC output.
- BYTE Channel
Enable
Enables the DAC Output.
- BYTE Channel
SetDeviceAddress
Writes a new device address into EE memory. The use LDAC pin component property must be set to true and the LDAC pin should be unique for every MCP4728 device connected to the I2C bus.
- BYTE OldAddress
Range: 0-7
- BYTE NewAddress
Range: 0-7
Configures the SPI peripheral ready for communications and initialises the internal variables. DAC needs to be enabled before any output voltage can be generated.
Pull Down Option
VREF Option
Gain Option
Vref Voltage
Steps
Number of discrete output states available from the DAC.
Control Bits
Resolution
Voltage Resolution
I2C Connections
Device Address
Channel selection
SDA
SCL
Baud Select
Baud rate to be used
Stop Delay
Use LDAC Pin
Allows the LDAC pin to be driven from an output pin on the microcontroller. If not used then tie the LDAC pin to GND to allow the DAC to function.
Simulation Comms
