Component: RFID (BL0197) (E-blocks 2)
Revision as of 14:10, 20 January 2023 by Wiki bot (talk | contribs)
Author Matrix Ltd.
Version 2.0
Category E-blocks 2
RFID (BL0197) component
Low level routines for controlling a BL0197 RFID E-block 2 board. Complete with macros to control the tag type and buzzer parameters.
Please click here for the component source code: FC_Comp_Source_EBlocks2_RFID_BL0197.fcfx
Fc9-comp-macro.png GetRFIDTypeID
Collects the 3 bytes required to determine which kind of MIFARE device is present. Stores the result into the local buffer 0 - 2 and returns the response of the module.
Fc9-comp-macro.png SetCardType
Allows the RFID tag type to be configured
Fc9-u8-icon.png - BYTE TagType
0 = MIFARE, 1 = ICODE, 2 = ISO14443B
Fc9-comp-macro.png WriteRFIDBlock
Writes a block of information to the RFID device.
Remote RFID Block Address.
Fc9-u8-icon.png - BYTE Key_Type
Fc9-comp-macro.png WriteRFIDModule
Stores a byte of data to the internal EEPROM of the RFID module at the address specified.
Fc9-u8-icon.png - BYTE Data
Fc9-comp-macro.png DecrementRFIDValue
Perfoms a 32-bit decrement on the number held in location page or block.
Fc9-u8-icon.png - BYTE Src
Page / Block
Fc9-u8-icon.png - BYTE Dst
Page / Block
Needed for MIFARE Commands
Fc9-comp-macro.png FormatRFIDValue
Initialises the internal buffer of the Microcontroller so that it is ready to perform a Increment, Decrement or Transfer command.
Fc9-comp-macro.png IncrementRFIDValue
Perfoms a 32-bit increment on the number held in location page or block.
Page / Block
Page / Block
Fc9-comp-macro.png StoreRFIDKey
Stores a 6 byte key for use with MIFARE type devices that require authorisation.
Key Location 0 - 31
Fc9-u8-icon.png - BYTE D0
Least significant byte of key
Fc9-u8-icon.png - BYTE D1
Fc9-u8-icon.png - BYTE D2
Fc9-u8-icon.png - BYTE D3
Fc9-u8-icon.png - BYTE D4
Fc9-u8-icon.png - BYTE D5
Most significant byte of key
Fc9-comp-macro.png WriteRFIDBuffer
Writes a byte of data to the outgoing buffer.
The address of the buffer 0 - 15
The data to be stored in the buffer location 0 - 255.
Fc9-comp-macro.png GetRFIDStatus
Collect the status of the RFID device (see help for the explaination of the status byte).
Fc9-comp-macro.png ReadRFIDBuffer
Reads a byte of data from the incoming buffer.
Fc9-comp-macro.png TransferRFIDValue
Perfoms a 32-bit block data transfer on the number held in location page or block.
Page / Block
Page / Block
Fc9-comp-macro.png GetRFIDUID
Collects the UID from a RFID device. Stores the result into the UID buffer and returns the response of the module.
Fc9-comp-macro.png ReadRFIDUID
Reads a byte of data from the UID buffer.
The address of the buffer 0 - 7
Fc9-comp-macro.png IsTagPresent
Checks to see if a card is present. Returns 0 if no tag is present. Returns 1 if a valid tag is present.
Fc9-comp-macro.png SetBeep
Allows the buzzer output to be configured
Fc9-u8-icon.png - BYTE BeepDelay
0 = Off, 1 = 40mS, 2 = 80mS, 3 = 120mS etc.
Fc9-comp-macro.png ReadRFIDBlock
Reads a block of information from the RFID device.
Fc9-comp-macro.png Initialise
Configures the RFID device by presetting the Osc type and Mode via the Flowcode component properties.
Fc9-type-16-icon.png Card_Type
Fc9-type-16-icon.png Beep Delay
Amount of time to activate the buzzer when detecting a new RFID tag.
Fc9-type-16-icon.png Channel
Fc9-type-16-icon.png Baud Options
Fc9-type-5-icon.png TX
Fc9-type-5-icon.png RX
Fc9-type-5-icon.png Card Detect (LED)
Fc9-type-5-icon.png CTS
Fc9-conn-icon.png Simulation
Fc9-type-10-icon.png Label
Fc9-type-21-icon.png Console Columns
Fc9-type-16-icon.png Data Source
