Component: Zigbee (BL0152) (E-blocks 2)
Revision as of 14:10, 20 January 2023 by Wiki bot (talk | contribs)
Category E-blocks 2
Zigbee component
Please click here for the component source code: FC_Comp_Source_EBlocks2_Zigbee_BL0152_2d.fcfx
Fc9-comp-macro.png NodeConfigureSleep
Sets the Zigbee device sleep mode (only applicable for end node type devices) ,
Fc9-u8-icon.png - BYTE Mode
1=Hibernate, 2=Doze, 4=Cyclic Sleep, 5=Cyclic Doze
Fc9-u16-icon.png - UINT Timeout
Time to sleep in milli seconds (ms)
Fc9-comp-macro.png ReadNameFromBuffer
Returns a byte from the 8-Byte name
Fc9-u8-icon.png - BYTE Device
The Device name to collect. Range: 0-7
Fc9-u8-icon.png - BYTE Idx
The index position of the name. Range: 0-7
Fc9-comp-macro.png NodeWake
Wakes up the local Zigbee module from sleep mode.
Fc9-comp-macro.png ReadATResponse
Reads a single byte from the received AT command response.
Fc9-u8-icon.png - BYTE idx
Specified the byte index in the buffer. Range 0-15
Fc9-comp-macro.png ScanBuffer
Returns a binary list of matched identifier names
Fc9-string-icon.png - STRING Compare_Str
Fc9-u8-icon.png - BYTE Length
Fc9-comp-macro.png SendChar
Transmits a byte value to the Zigbee module.
Fc9-u8-icon.png - BYTE Byte
Data byte to transmit. Range 0-255
Fc9-comp-macro.png InitNetwork
Initialises the Zigbee module and attempts to setup or join the network
Fc9-comp-macro.png ConnectToCoordinator
Attempts to connect the data channel to the network coordinator node.
Fc9-comp-macro.png ConnectToName
Attempts to connect the data channel to a named device on the network.
Fc9-string-icon.png - STRING Name
Fc9-comp-macro.png EnterCommandMode
Moves from data mode into command mode by sending the special characters
Fc9-comp-macro.png RestartNetwork
Attempts to restart the network
Fc9-comp-macro.png StoreParams
Stores the current register set into the Zigbee module's non volatile memory
Fc9-comp-macro.png ConnectToAll
Attempts to connect the data channel to all devices on the network.
Fc9-comp-macro.png ConnectFromLibrary
Attempts to connect the data channel to a known device on the network.
Fc9-comp-macro.png ConnectToAddress
Attempts to connect the data channel to a specific device address on the network.
Fc9-string-icon.png - STRING Address
Fc9-comp-macro.png GetSignalLevel
Returns the signal strength of the last signal received
Fc9-comp-macro.png ExitCommandMode
Returns from command mode to allow data to be sent and received
Fc9-comp-macro.png ReadAddressFromBuffer
Reads a byte from a 16-bit Zigbee device address
Fc9-comp-macro.png SendATCommand
Transmits a string of values to the Zigbee module.
Fc9-string-icon.png - STRING Command
Transmits a command to the Zigbee module followed by a carriage return
Fc9-comp-macro.png ScanNetwork
Scans the local network for devices and stores into a local device array. Mode = 0 store device names, mode = 1 store device addresses. Returns the number of devices found.
Fc9-comp-macro.png GetATResponse
Waits for a response from the Zigbee module. If the Logging parameter is set then the response is stored in memory allowing the software to read the reply.
Fc9-u8-icon.png - BYTE Logging
Fc9-comp-macro.png ReceiveChar
Attempt to receive a byte from the Zigbee module.
Fc9-u8-icon.png - BYTE nTimeout
Fc9-type-10-icon.png Device Name
String of characters used to allow the Zigbee node to use the name addressing mode of operation. Can be left blank if name addressing is not being used.
Fc9-type-16-icon.png Zigbee Mode
Specifies the functionality of the Zigbee node. Coordinator - Must be used with a Coordinator Zigbee E-Block EB051C, Responsible for starting the network and assigning addresses. Router - Must be used with a Router / End Node E-Block EB051R, Responsible for forwarding / repeating packets on the network. End Device - Must be used with a Router / End Node E-Block EB051R, Capable of low power operation.
Fc9-type-7-icon.png Auto ID
Automatically generate a PAN ID
Fc9-type-10-icon.png PAN ID
Assigns a Personal Area Network Identifier code to the Zigbee node. Random / Search - Scans the local area for Zigbee PAN networks and joins the existing network, otherwise a random value is chosen. Preset - Assigns a preset PAN ID to the Zigbee node, Must be between 0x0 and 0x3FFF.
Fc9-type-16-icon.png Node Join Time
Length of time in seconds where nodes are allowed to join the network. Infinte - Nodes are always allowed to join the network. Preset - Nodes are only allowed to join the network for a specific amount of time. Note: Join time not available for End Device nodes.
Fc9-type-14-icon.png Max Hops
Specifies the maximum number of retransmits for a Broadcast transmission.
Fc9-type-16-icon.png Sleep Buffer Time
Length of time to buffer packets for sleeping or powered down nodes. This value must be consistent throughout the Zigbee network. Default - Assigns the maximum buffer time of 28 seconds. Preset - Allows for a custom sleep time of 0.32 - 28 seconds.
Fc9-type-16-icon.png Channel
Fc9-type-5-icon.png TX
Fc9-type-16-icon.png TX Remap Pin
Allows the hardware transmit pin to be configured from a list of available pins based on your target device,
Fc9-type-5-icon.png RX
Fc9-type-16-icon.png RX Remap Pin
Allows the hardware receive pin to be configured from a list of available pins based on your target device,
Fc9-type-16-icon.png Baud Options
Fc9-type-16-icon.png Use Flow Control
Fc9-type-5-icon.png RTS
Pin to be used for Request To Send handshake function Output from target micro to inform remote device we are ready to receive data. Low = Ready to receive data High = Not ready to receive data
Fc9-type-5-icon.png CTS
Pin to be used for Clear To Send handshake function. Input to target micro to inform when the remote device is ready to transmit data. Low = Ready to transmit data High = Not ready to transmit data
Fc9-type-5-icon.png Sleep Pin
Zigbee Sleep Control Pin
Fc9-conn-icon.png Scan Channels
Fc9-type-7-icon.png 0x0B
Determines if channel will be scanned
Fc9-type-7-icon.png 0x0C
Fc9-type-7-icon.png 0x0D
Fc9-type-7-icon.png 0x0E
Fc9-type-7-icon.png 0x0F
Fc9-type-7-icon.png 0x10
Fc9-type-7-icon.png 0x11
Fc9-type-7-icon.png 0x12
Fc9-type-7-icon.png 0x13
Fc9-type-7-icon.png 0x14
Fc9-type-7-icon.png 0x15
Fc9-type-7-icon.png 0x16
Fc9-type-7-icon.png 0x17
Fc9-type-7-icon.png 0x18
Fc9-type-7-icon.png 0x19
Fc9-type-7-icon.png 0x1A
Fc9-type-14-icon.png Scan Duration
Configures the length of time to scan each channel for network activity. The overall time for the entire channel scan is shown as channel scan time.
Fc9-type-14-icon.png Total Scan Time (ms)
The total amount of time that it will take to perform a complete RF channel scan based on the selected scan channels and duration.
Fc9-conn-icon.png Simulation
Fc9-type-10-icon.png Label
Fc9-type-21-icon.png Console Columns
Fc9-type-16-icon.png Data Source
