Component: FTDI (FT800) (FT800) (Misc)
Jump to navigationJump to searchAuthor | MatrixTSL |
Version | 2.0 |
Category | Misc |
FTDI (FT800) component
The FT800 provides a powerful feature set in a small package to create dynamic HMI interfaces. The device supports line by line graphics rendering to 1/16 of a pixel on displays with resolution up to 512 x 512 with 262K colours. The chip includes a touch controller for sensing touch feedback from a TFT display with a resistive touch panel as well as a sound synthesizer and audio playback with a PWM output to drive a speaker.
Please click here for the component source code: FC_Comp_Source_FTDI-FT800.fcfx
MemRead16 |
Reads a single unsigned int from the FT800 internal address space | |
Address |
Return |
MemRead8 |
Reads a single data byte from the FT800 internal address space | |
Address |
Return |
MemRead32 |
Reads a single unsigned long from the FT800 internal address space | |
Address |
Return |
MemWrite16 |
Writes a unsigned int value to the FT800 internal address space | |
Address |
Data |
Return |
MemWrite8 |
Writes a byte value to the FT800 internal address space | |
Address |
Data |
Return |
CommandWrite |
Sends FT800 command | |
Command |
Return |
MemWrite32 |
Writes a unsigned long value to the FT800 internal address space | |
Address |
Data |
Return |
Initialise |
System initialization routines. Executed once on reset. Returns 0 if device not detected or 1 if device is correctly initialised. | |
Return |
