Component: GLCD (EB076) (EB076) (E-blocks 1)
Revision as of 14:11, 20 January 2023 by Wiki bot (talk | contribs)
Version 2.0
Category E-blocks 1
GLCD (EB076) component
Graphical display component designed to work with the Picaso range of displays from 4D Systems. Also available in the form of the EB076 GLCD Touchscreen E-block. Component based around the uLCD-32PT display.
Please click here for the component source code: FC_Comp_Source_GLCD_4D_EB076.fcfx
G4D_InitialiseCard
Initialises the micro SD card inserted into the module is available. Returns 0 for succesful initialisation or 255 for a detected failure.
G4D_DumpScreenToFilePicaso
Copies a section of the display to the micro SD card starting from X, Y and ranging to Width, Height.
- UINT X
- UINT Y
- UINT Width
- UINT Height
- STRING Filename
Assigns the name of the file on the card to store the data.
G4D_ReadTouchCoordinatesPicaso
Returns the coordinates of the last touch event. Axis = 0 or 'x' or 'X' - Returns the X coordinate. Axis = 1 or 'y' or 'Y' - Returns the Y coordinate.
- BYTE Axis
G4D_GetTouchCoordinatesPicaso
Reads the value of the last touchscreen input from the display. Returns a 0 if no new touch is detected. Returns a 1 if a press is detected. Returns a 2 if a release is detected. Returns a 3 if a moving drag is detected.
- INT Number
- UINT X
- UINT Y
- BYTE Font
Size of the font - 0 = Normal, 1 = Double Width, 2 = Double Width and Height, 3 = Double Height
- BYTE Transparent
DrawLine
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
G4D_DisplayImageFromFilePicaso
Attempts to print an image from the micro SD card using the specified filename on the card. The image is printed at location starting from X, Y. PosH and PosL specify the sector address of the previously stored image icon.
- UINT X
- UINT Y
- STRING Filename
- UINT PosH
- UINT PosL
G4D_DisableTouchscreenPicaso
Disables the touchscreen interface if available.
DrawEllipse
- UINT X
- UINT Y
- UINT XRadius
- UINT YRadius
- BYTE Transparent
- BYTE Solid
Plot
- UINT X1
- UINT Y1
DisplayControl
Controls the operation, contrast and backlight on the display
- BYTE Backlight
0=Backlight Off, 1=Backlight On (default)
- BYTE Display
0=Display off, 1=Display on (default)
- BYTE Contrast
Contrast Range 0 - 15
FastPlot
G4D_EnableTouchscreenPicaso
Enables the touchscreen interface if available.
G4D_DisplayVideoFromCard
Attempts to display a sequence of images from the micro SD card at the specified address location on the card. The images are printed at location starting from X, Y and ranging to Width, Height.
- UINT X
- UINT Y
- UINT Width
- UINT Height
- BYTE ColourMode
Specifes the colour depth setting - 0 = 8-bit colour, 1 = 16-bit colour.
- BYTE Delay
Specifies the number of milliseconds to wait in between displaying each image.
- UINT Frames
Specifies the number of frames to display.
- BYTE AddH
- BYTE AddM
- BYTE AddL
G4D_SetVolumePicaso
Sets the playback volume.
- BYTE Volume
Volume = 0 - Mute Enabled / 1 - Volume Down 8 / 3 - Volume Down 1 / 253 - Volume Up 1 / 254 - Volume Up 8 / 255 - Mute Disabled / 8 - Minimum Volume Level / 127 - Maximum Volume Level
SetDisplayOrientation
- BYTE Orientation
BPlot
- UINT X1
- UINT Y1
Window
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
Print
- STRING Str
- UINT X1
- UINT Y1
- BYTE Font
- BYTE Transparent
G4D_DumpScreenToCard
Copies a section of the display to the micro SD card starting from X, Y and ranging to Width, Height. The address parameters assign where on the card to store the data.
- UINT X
- UINT Y
- UINT Width
- UINT Height
- BYTE AddH
- BYTE AddM
- BYTE AddL
G4D_SetVGADisplaySizePicaso
Specifies the VGA display size in pixels. Size = 0 - 320 x 240 Resolution. Size = 1 - 640 x 480 Resolution. Size = 2 - 800 x 480 Resolution. Size = 3 - Custom Resolution
- BYTE Size
ClearDisplay
SetBackgroundColour
- BYTE Red
- BYTE Green
- BYTE Blue
DrawCircle
- UINT X
- UINT Y
- UINT Radius
- BYTE Transparent
- BYTE Solid
G4D_DisplayImageFromCard
Attempts to print an image from the micro SD card at the specified address location on the card. The image is printed at location starting from X, Y and ranging to Width, Height.
- UINT X
- UINT Y
- UINT Width
- UINT Height
- BYTE ColourMode
Specifies the colour depth setting - 0 = 8-bit colour, 1 = 16-bit colour.
- BYTE AddH
- BYTE AddM
- BYTE AddL
SetForegroundColour
- BYTE Red
- BYTE Green
- BYTE Blue
G4D_SetTouchRegionPicaso
Specifies the area of the screen which will respond to touchscreen inputs.
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
G4D_PlayAudioFromFilePicaso
Attempts to stream an audio wav file from the micro SD card using the specified filename.
- BYTE Play_Option
Play_Option = 0 - Return when playing complete / 1 - Return immediatley / 2 - Stop Playback / 3 - Pause Playback / 4 - Resume Playback / 5 - Loop Playing until stopped
- STRING Filename
DrawRectangle
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
- BYTE Transparent
- BYTE Solid
Dimensions
Pixel Height
Pixel Width
Colour
Monochrome
Foreground Color
Background Colour
Bit Depth
Colour Bit Depth
Red Bit Depth
Green Bit Depth
Blue Bit Depth
TX
RX
Reset Pin
I/O pin connected to the reset signal on the gLCD
Baud Options
High Speed
Determines if the baud rate is automaticaly switched from 9600 baud on initialise to 57600 baud. Only available in hardware mode.
Component Label
Component Label Scale
Physical Orientation
Console Columns
Data Source
Display Method
