| Author | Matrix Ltd |
| Version | 1.5 |
GLCD (ST7565R) SPI component
Graphical display component designed to work with the ST7565 type monochrome displays. Transfers data using a 4-wire SPI interface, cannot read back so pixel based routines won't work.
Please click here for the component source code: FC_Comp_Source_GLCD_ST7565R_SPI.fcfx
|   | ReadFontWidth |
|  - BYTE | Font |
|  - BYTE | Character |
|  - BYTE | Return |
|   | SetFontScaler |
|  - BYTE | ScaleX |
|  - BYTE | ScaleY |
|  - VOID | Return |
|   | PrintNumber |
|  - INT | Number |
|  - UINT | X |
|  - UINT | Y |
|  - BYTE | Font |
|  - BYTE | Transparent |
|  - VOID | Return |
|   | DrawLine |
|  - UINT | X1 |
|  - UINT | Y1 |
|  - UINT | X2 |
|  - UINT | Y2 |
|  - VOID | Return |
|   | DrawEllipse |
|  - UINT | X |
|  - UINT | Y |
|  - UINT | XRadius |
|  - UINT | YRadius |
|  - BYTE | Solid |
|  - VOID | Return |
|   | SetDisplayOrientation |
|  - BYTE | Orientation |
|  - VOID | Return |
|   | BPlot |
|  - UINT | X1 |
|  - UINT | Y1 |
|  - VOID | Return |
|   | ReadFontStat |
|  - BYTE | Font |
|  - BYTE | Index |
|  - BYTE | Return |
|   | Print |
|  - STRING | Str |
|  - UINT | X1 |
|  - UINT | Y1 |
|  - BYTE | Font |
|  - VOID | Return |
|   | ClearDisplay |
|  - VOID | Return |
|   | SetBackgroundColour |
| Specifies the colour of the foreground |
|  - BYTE | PixelColour |
| 0=White, 1=Black |
|  - VOID | Return |
|   | DrawCircle |
|  - UINT | X |
|  - UINT | Y |
|  - UINT | Radius |
|  - BYTE | Solid |
|  - VOID | Return |
|   | Write_Command |
|  - BYTE | Command |
|  - VOID | Return |
|   | SetForegroundColour |
| Specifies the colour of the foreground. |
| 0=White, 1=Black |
|  - VOID | Return |
|   | DrawRectangle |
|  - UINT | X1 |
|  - UINT | Y1 |
|  - UINT | X2 |
|  - UINT | Y2 |
|  - BYTE | Solid |
|  - VOID | Return |
|   | Initialise |
|  - VOID | Return |
|   | Properties |
|   | Dimensions |
|   | Pixel Width |
|   | Pixel Height |
|   | Colour |
|   | Monochrome |
|   | Foreground Color |
|   | Background Color |
|   | Bit Depth |
|   | Color Bit Depth |
| Number of bits of colour depth available on the display |
|   | Red Bit Depth |
| Number of bits of Red colour depth on the display |
|   | Green Bit Depth |
| Number of bits of Green colour depth on the display |
|   | Blue Bit Depth |
| Number of bits of Blue colour depth on the display |
|   | Connections |
|   | Channel |
| SPI Channel selector |
|   | Prescale |
| Prescale option selector |
|   | MOSI |
| SPI Data Out Pin SDO - Also Known as Master Out Slave In (MOSI) when used in Master mode. |
|   | MOSI Remap Pin |
| Select which the target pin to assign the MOSI hardware pin functionality. |
|   | MISO |
| SPI Data In Pin SDI - Also Known as Master In Slave Out (MISO) when used in Master mode. |
|   | MISO Remap Pin |
| Select which the target pin to assign the MISO hardware pin functionality. |
|   | CLK |
| SPI Clock Pin CLK - The Clock signal is driven by the SPI master. |
|   | CLK Remap Pin |
| Select which the target pin to assign the CLK hardware pin functionality. |
|   | CS |
| Chip select pin |
|   | A0 |
| Address pin to tell the display if we are sending commands or data |
|   | Fonts |
|   | Font Count |
|   | Font 0 |
|   | Font |
|   | Character Spacing |
|   | Space Width |
|   | Simulation Mode |
|   | Physical Orientation |
|   | Simulate Comms |
| Allows the communications to be simulated to either see the waveforms on the data recorder or to drive an injector component. |
