Component: HBRIDGE (CAL) (Misc)
| Version | 2.1 |
| Category | Misc |
HBRIDGE component
CAL = Code Abstraction Layer - Allows one code base to run on a wide range of chips. A low level implementation giving direct access to the H-Bridge peripheral. Currently only supports compatible 8-bit PIC devices.
Please click here for the component source code: FC_Comp_Source_HBRIDGE.fcfx
Half Bridge Application
A Half Bridge type output has two output signals A and B.
Full Bridge Application
Full Bridge type output has four output signals A, B, C and D.
A simple proof of concept example to drive a full bridge output with varying speed and direction.
| GetValue | |
| Returns Named property Value | |
| Name | |
| Disable | |
| Disable this PWM Channel | |
| Enable | |
| Enable this PWM Channel | |
| SetSpeed | |
| Sets the motor speed by varying the PWM duty. | |
| duty | |
| Duty value 0 - 1023 | |
| SetValue | |
| Sets the Value of the property PERIOD, PRESCALE or CHANNEL (if CHANNEL also updates the PORT from FCD) | |
| Name | |
| Value | |
| SetDirection | |
| Set the motor direction. | |
| direction | |
| 0 = Forwards, 1 = Reverse | |
| GetList | |
| Returns CHANNEL or PRESCALE list from the FCD and updates the internal property | |
| Name | |
