API FCD.GetPathHandle
Revision as of 11:08, 10 June 2013 by JonnyW (talk | contribs) (XML Import to change Variable types into Variable Types)
<sidebar>API contents</sidebar> Gets a FCD paths handle, suitable for traversal with the Tree API
Class hierarchy
FCD
GetPathHandle
STRING PathName
The '.' separated path through the FCD to look in
HANDLE StartPoint
The handle of an existing FCD path to start the search
HANDLE
Returns the FCD paths handle, suitable for traversal with the Tree API
  • Add to a calculation icon:
    result = ::FCD.GetPathHandle("pathname", startpoint)
