Component: MIAC (PIC) (Misc)
Revision as of 14:12, 20 January 2023 by Wiki bot (talk | contribs)
Version 1.7
Category Misc
MIAC (PIC) component
MIAC - Matrix Industrial Automotive Controller PLC type module based on a PIC18F4455 device, produced by Matrix Component includes functions to drive the functionality of the MIAC and MIAC system.
Please click here for the component source code: FC_Comp_Source_MIAC.fcfx
Analogue Input
Basic example of how to read an analogue input on the MIAC and display it on the LCD. MIAC ADC LCD
Keypad Input
Basic example of how to read the keypad and display the value on the LCD. MIAC Keypad For reference the numbering of the MIAC keypad looks like this.
Output Control
Basic example of how to control all of the individual outputs on the MIAC using the keypad.
Note that for the transistor outputs to come on you must wire a connection from the +V terminal to the M terminal.
If you are driving high current outputs then you can instead supply separate DC power to the M terminal. MIAC Outputs
MIAC Interrupt Controlled Clock
Basic example of how to create a timer interrupt based clock. MIAC Clock
InputANALOG_10Bit
Returns the 10 bit value for the analogue input requested by parameter InputID (Inputs 1 to 8)
- BYTE InputID
The input to read from 1 to 8.
- INT Return
RelayOFF
Turns off the requested relay given by parameter RelayID, values 1 to 4
- BYTE RelayID
The relay to turn off. From 1 to 4.
PrintString
Prints the given character string to the display at the current cursor position and moves the cursor position.
- STRING Str
The string to send to the display.
GetKeypad
Returns the key code of the key that is pressed, otherwise if nothing is pressed then returns 255
DisplayStart
Initialise the display ready for use
DisplayCommand
Sends the given command to the display
- BYTE Cmd
PrintASCII
Prints the given character to the display at the current cursor position and increments the cursor position.
- BYTE Char
ASCII code of the character to print.
Prints the given number to the display starting at the current cursor position and moves the cursor position.
- INT n
PrintFormattedNumber
- ULONG Number
- BOOL Format
0=Signed, 1=Unsigned
DisplayClear
Clears the display to white space
RelayON
Turns on the requested relay given by parameter RelayID, values 1 to 4
- BYTE RelayID
The relay to turn on from 1 to 4.
OutputOFF
Outputs a digital low state on the output requested by parameter TransID (Outputs 1 to 4)
- BYTE TransID
1 to 4 (Outputs A to D)
DisplayCursor
Moves the display cursor to the given position. If the cursor is set to the origin at x=0, y=0, then the next character sent to the display will appear in the top left corner.
- BYTE x
Position of the cursor in characters from left to right.
- BYTE y
The line to move the cursor to.
OutputON
Outputs a digital high state on the output requested by parameter TransID (Outputs 1 to 4)
- BYTE TransID
InputDIGITAL
Returns the digital state of the input requested by parameter InputID (Inputs 1 to 8)
- BYTE InputID
The input number from 1 to 8.
InputANALOG
Returns the 8 bit value for the analogue input requested by parameter InputID (Inputs 1 to 8)
- BYTE InputID
