Component: Servo Motor (Tower Pro 9g) ()
Revision as of 14:12, 20 January 2023 by Wiki bot (talk | contribs)
Version 1.1
Category
Servo Motor (Tower Pro 9g) component
Small size 9g servo motor suitable for control by the 'Servo Controller' component. Use the 'Link to...' property to attach other objects to the rotor for emulating mechanical systems. Send a virtual PWM signal to the servo by selecting it as a target of the 'Servo Controller' component.
Please click here for the component source code: FC_Comp_Source_Micro_Servo_9G.fcfx
Please note that the servo motor template and child components require the Servo Controller component to control them.
Controlling a servo with an analogue input
This example reads the value of the analogue potentiometer and uses this to set the position of the servo motor. FC6 Icon.png Servo Example 1 The Servo controller is linked to the standard servo component but this could be linked to any object on the panel.
Creating a multi-axis actuator using servo motors
This example links two servo motors together using panel primitive objects and groups. FC6 Icon.png Servo Example 2 The Servo controller can handle up to 8 motors and is used to control both of the standard servo components on the panel.
Fc9-type-17-icon.png Link To...
Select a panel object here to connect it 'mechanically' to the servo's actuator. The selected object will now be moved whenever the servo position changes. NB) To move multiple objects, first group the objects, and then select the group.
Fc9-type-7-icon.png Reverse Output
Some manufacturers motors may rotate in different ways to others. Changing this property allows you to flip the direction of the motor.
Fc9-type-16-icon.png Movement Type
