Component: One Wire Dummy (Misc)
Revision as of 14:12, 20 January 2023 by Wiki bot (talk | contribs)
Version 1.4
Category Misc
One Wire Dummy component
Low level routines for controlling or interacting with a standard one wire interface.
Please click here for the component source code: FC_Comp_Source_One_Wire_Dummy.fcfx
Fc9-comp-macro.png ReceiveByte
Fc9-comp-macro.png TransmitByte
Transmit a byte to the one wire bus a bit at a time
Fc9-u8-icon.png - BYTE Command
Fc9-comp-macro.png SkipROM
Performs a bus reset and the sends the SkipROM command byte
Fc9-comp-macro.png BusReset
Issue a 'ping' on the bus. If there is at least one sensor on the bus then it will generate a presence pulse. Returns 0 if a presense pulse was detected Returns 1 no device was detected
Fc9-comp-macro.png MatchROM
Performs a reset followed by the MatchROM code and then the 8-bit ROM code.
Fc9-u8-icon.png - BYTE FamilyCode
Fc9-u8-icon.png - BYTE SerialNumber
Fc9-comp-macro.png ScanBus
Scans the one wire bus to detect all connected devices. Returns the number of one wire devices found.
Fc9-comp-macro.png GetDeviceCount
Fc9-comp-macro.png GetIDByte
Returns byte ectet of the 64-Bit lasered ROM code, 255 on error
Fc9-u8-icon.png - BYTE Device
Device ID - Range: 0 - NumDevices - 1
Fc9-u8-icon.png - BYTE ByteIndex
Index of the data byte. 0=FamilyCode, 1-6=Serial, 7=CRC
Fc9-comp-macro.png Initialise
Sets up the 1-Wire output pin ready for communications.
