Component: PWM 16CH 12Bit (PCA9685) (General Output)
Revision as of 14:12, 20 January 2023 by Wiki bot (talk | contribs)
Category General Output
PWM 16CH 12Bit (PCA9685) component
The PCA9685 is an I²C-bus controlled 16-channel LED controller optimized for Red/Green/Blue/Amber (RGBA) color backlighting or Servo motor applications. Each output has its own 12-bit resolution (4096 steps) fixed frequency individual PWM controller that operates at a programmable frequency from a typical of 24 Hz to 1526 Hz. All outputs are set to the same PWM frequency. Up to 64 devices can be chained together on a single I²C-bus to provide up to 1024 individual PWM outputs.
Please click here for the component source code: FC_Comp_Source_PCA9685_16_Channel_PWM.fcfx
Reset
Sends a reset command to the PCA9685 chip over I2C
SetPWMFrequency
Sets the PWM frequency for the entire chip, up to approx 1.6 KHz
- FLOAT Frequency
Floating point frequency that we will attempt to match
SetOutputMode
Sets the output mode of the PCA9685 to either open drain or push pull. Warning: LEDs with integrated zener diodes should only be driven in open drain mode.
- BOOL Mode
0=OpenDrain, 1=Push/Pull
Sleep
Puts the module into Sleep mode
SetExternalClock
Sets EXTCLK pin to use the external clock
- BYTE Prescale
External Clock Prescaler - Range: 3-255
SetAddress
Allows a different I2C address to be specified allowing one component to control multiple PCA9685 modules.
- BYTE Address
Range: 0x40 - 0x7F
SetClockFrequency
Sets the current clock frequency, used for things like calculating the PWM frequency and Microsecond duty.
- ULONG Clock
GetClockFrequency
Returns the current clock frequency
- ULONG Return
WriteMicroseconds
Sets the PWM output of one of the PCA9685 pins based on the input microseconds, output is not precise
- BYTE Output
One of the PWM output pins - Range: 0 to 15
- UINT Microseconds
The number of Microseconds to turn the PWM output ON
SetPWM
- BYTE Output
- UINT On
At what point in the 4096-part cycle to turn the PWM output ON
- UINT Off
At what point in the 4096-part cycle to turn the PWM output OFF
Sets up the I2C ready for communications to begin
WakeUp
Wakes the module from Sleep mode
SetPin
Sets pin without having to deal with on/off tick placement and properly handles a zero value as completely off and 4095 as completely on.
- BYTE Output
- UINT Duty
The number of ticks out of 4096 to be active
- BOOL Invert
0=Normal, 1=Inverted
Address
Module I2C Address. This setting can be overridden using the SetAddress component macro.
Output Mode
Sets the output mode of the PCA9685 to either open drain or push pull. Warning: LEDs with integrated zener diodes should only be driven in open drain mode. Can be overridden using the SetOutputMode component macro.
Clock Type
Configures the input clock source to the module.
Clock Frequency
Frequency of the module. Internal oscillator defaults to 250000000 or 25MHz but can actually be anywhere from 23 to 27MHz. External clock frequency can be specified here up to a max value of 50000000 or 50MHz. This setting can be overridden using the SetClockFrequency component macro.
Prescaler
External Clock Prescaler Range: 3 to 255
Target PWM Frequency
The ideal PWM frequency we would like to generate on the output pins. Servo motors require an output frequency around 50Hz. LEDs require a mugh higher output frequency to avoid visible flicker.
Actual PWM Frequency
The calculated actual PWM frequency available using the Clock Frequency and Prescaler
PWM Resolution
Number of microseconds the PWM output can resolve to
I2C Communications
Channel selection
Baud Select
Baud rate to be used
SDA
SCL
Stop Delay
Simulate Comms
