Component: TCP/IP Dummy (ENC28J60) (Comms: Networking)
Revision as of 14:13, 20 January 2023 by Wiki bot (talk | contribs)
Version 2.0
Category Comms: Networking
TCP/IP Dummy component
A set of routines used to control a ENC28J60 TCP/IP Module. Required connections VCC, Reset, GND, SCK, MISO, MOSI, CS. Leave these pins disconnected CLKOUT, ENC_WOL, ENC_INT
Please click here for the component source code: FC_Comp_Source_TCPIP_ENC28J60_Dummy.fcfx
Here is a simple example to help get started with the ENC28J60 module.
The example program creates a web page server on the network and will also respond to ping requests.
The HTML to drive the web pages is included in the flowchart near the bottom of the main program loop. FC6 Icon.png ENC28J60 Example
Fc9-comp-macro.png PacketSend
Attempts to transmit a data packet to the ENC28J60 module.
Fc9-comp-macro.png MakeTcpSynackFromSyn
Fc9-u16-icon.png - UINT Port
Fc9-comp-macro.png MakeArpRequest
[[File:]] - ServerIP
Fc9-comp-macro.png InitialiseDataLengthInfo
Initialises the data pointers to allow us to craft a response containing data
Fc9-comp-macro.png MakeTcpAckFromAny
Fc9-comp-macro.png PacketReceive
Attempts to receive a data packet from the ENC28J60 module. Returns the number of bytes received.
Fc9-comp-macro.png CheckForTCPType
Checks to what kind of TCP type the received data is requesting. Returns a bit field specifying the type of request. 0x01 = Ack Requires, 0x02 = Synchronise 0x10 = Ack
Fc9-comp-macro.png CheckArpPacketIsMyreplyArp
Fc9-comp-macro.png CheckForIp
Checks to see if the received data is an IP request with my IP address.
Fc9-comp-macro.png CheckForTCPPort
Checks to see if the received data is requesting the server port
Fc9-comp-macro.png CheckForPing
Checks to see if the received data is a Ping request
Fc9-comp-macro.png GetModuleRevision
Requets the module revision number and returns the value supplied by the module's firmware.
Fc9-comp-macro.png MakeTcpAckWithData
Fc9-u16-icon.png - UINT DataLength
Fc9-comp-macro.png MakeArpAnswerFromRequest
Fc9-comp-macro.png ReadRegister
Reads the value from a single register onboard the ENC28J60 module.
Fc9-comp-macro.png CheckForARP
Checks to see if the received data is an ARP request with my IP address.
Fc9-comp-macro.png ClientSendPacket
Fc9-u16-icon.png - UINT DestPort
Fc9-u16-icon.png - UINT SourcePort
Fc9-u8-icon.png - BYTE Flags
Fc9-u8-icon.png - BYTE MaxSegmentSize
Fc9-u8-icon.png - BYTE ClearSeqAck
Fc9-u16-icon.png - UINT NextAckNum
Fc9-u8-icon.png - BYTE DestMac
Fc9-u8-icon.png - BYTE DestIp
Fc9-comp-macro.png MakeEchoReplyFromRequest
Fc9-comp-macro.png ControlLEDs
Allows both the LEDs on the Ethernet socket to be controlled. Useful for checking if the SPI communications are functioning correctly.
Fc9-u8-icon.png - BYTE Mode
0=Off, 1=On, 2=Auto
Fc9-comp-macro.png GetDataLength
Returns the number of received data bytes after the headers
Fc9-comp-macro.png GetTcpDataPointer
Fc9-comp-macro.png WriteRegister
Writes a value to a single register onboard the ENC28J60 module.
Fc9-u8-icon.png - BYTE Data
Fc9-comp-macro.png FillTcpData
Fc9-u16-icon.png - UINT Position
Fc9-comp-macro.png ReadStringFromBuffer
Reads a string from the buffer at location specified for the number of bytes specified. If a space character is encountered then the macro will return straight away without the space character in the string.
Fc9-u16-icon.png - UINT BufferLocation
Fc9-u8-icon.png - BYTE NumberOfBytes
Number of bytes to read from the buffer and store into string
Fc9-comp-macro.png GetSendersMAC
Gets the MAC address from locations 6-11 of the IP Header
Fc9-u8-icon.png - BYTE MAC
6-byte Array to store the MAC address
Fc9-comp-macro.png FillTcpArray
Fc9-u16-icon.png - UINT Count
Initialises the SPI connection to the TCPIP module and sets up some initial values. Flashes the LEDs on and off twice to confirm SPI comms are active. LEDs are then configured to auto functionality.
