| Author
Matrix Ltd
| Version
1.0
| Category
Segment
7Segment (Quad TM1637) component
Quad seven segment display using an two pin communications bus to reduce the number of control pins. Driven using a TM1637 quad 7-segment display driver.
Please click here for the component source code: FC_Comp_Source_TM1637_7SEG_Quad_Driver_2dgi.fcfx
ShowDigits
| Set the number and decimal point to be displayed in the given digit of the display.
- BYTE
Value0
| The number value to set the digit to (0...15), 16=Clear
- BYTE
Value1
- BYTE
Value2
- BYTE
Value3
- BYTE
Colon
| Whether to show the colon character.
SetBrightness
| Controls the brightness of the 7-seg displays
- BYTE
Brightness
| Range: 0-7 - 0=Darkest, 7=Brightest
- BOOL
On
| 0 = Display Off, 1 = Display On
ShowSegments
| Allows for manual control over the display segments. The colon character can also be controlled when writing to digit 1.
- BYTE
Digit
| Which of the four digits to change. (0...3)
- BYTE
Segments
| The binary segment value to display
ShowDigit
| Set the number to be displayed in the given digit of the display. The colon character can also be controlled when writing to digit 1.
- BYTE
Digit
- BYTE
Value
- BYTE
Colon
| Whether to show the colon character. Digit 1 only.
Display Type
| Set this according to the specification of your hardware display. Common Anode: Pin true -> LED Off, Pin false -> LED On Common Cathode: Pin true -> LED On, Pin false -> LED Off
Show Seg Labels
| Show segment name labels overlayed over the component.
DIO
| Data Pin connection to TM1637 IC
CLK
| Clock Pin connection to TM1637 IC
Colors
LED Color
| Color of the LED segments when truned on. When off, they use a much darker shade of the same hue.
Body Color
| Color of the plastic casing containing the LEDs.
Label Color
| Color for the optional LED segment labels.
