Component: Thermocouple (MCP960X) (Environmental)
| Version | 1.1 |
| Category | Environmental |
Thermocouple (MCP960X) component
Component to interface the MCP960X IC from Microchip. Uses a standard 2-wire I2C interface to connect to the IC and collect the temperature. IC available in different versions to suit different thermocouple types.
Please click here for the component source code: FC_Comp_Source_ThermocoupleMCP960X.fcfx
Here is a basic example to display both the thermocouple temperature and IC surface temperature.
Sim Demo
| ReadReference_Int | |
| Returns the Reference (IC die) temperature from the last sample as an integer value. Use Sample first, which samples both reference & themocouple temperatures. | |
| ReadRawDataADC | |
| Returns the thermocouple temperature from the last sample as an integer value in Degrees C. | |
| ReadReference_Float | |
| Returns the reference (IC die) temperature from the last sample as a floating point. Use Sample first, which samples both reference & themocouple temperatures. | |
| ReadThermocouple_Int | |
| Returns the thermocouple temperature from the last sample as an integer value. Use Sample first, which samples both reference & themocouple temperatures. | |
| ReadThermocouple_Float | |
| Returns the thermocouple temperature from the last sample as a floating point value. Use Sample first, which samples both reference & themocouple temperatures. | |
| Configures the I2C bus ready for communications. | |
