Component: WAV Library File (Audio Output)
| Category | Audio Output |
WAV Library File component
Allows WAV files to be played or recorded using a file component to provide the data. Complete with buffer to allow for uninterrupted playback when performing other tasks. Playback compatible with analogue outputs such as DAC or PWM. Recording compatible with analogue inputs such as a Microphone.
Please click here for the component source code: FC_Comp_Source_WAV_Player_FAT.fcfx
| EndOfFile | |
| A simple check to see if we are at the end of the file. Returns 0 if we and not yet at the end fo the file. Returns 1 if we are at the end of the file. | |
| StopRecording | |
| GetNumChannels | |
| Returns the number of audio channels stored in the WAV file during playback. | |
| GetBitsPerSample | |
| Returns the number of bits per sample during playback. | |
