API Expand.MacroHead
Revision as of 11:08, 10 June 2013 by JonnyW (talk | contribs) (XML Import to change Variable types into Variable Types)
<sidebar>API contents</sidebar> Expands a macro name to the code generated for the header of that macro
Class hierarchy
Expand
MacroHead
STRING Source
The macro name to expand
STRING ExpandedName
Result of Expand.MacroName(), empty for default
HANDLE Owner
A component that owns the macro
BOOL AddHead
Add the macro name
BOOL AddLocals
Tab-indent to generate the code at
STRING
  • Declare a variable 'result' of type STRING
  • Add to a calculation icon:
    result = ::Expand.MacroHead("source", "expandedname", owner, true, false)
