API Expand.MacroTail
Revision as of 11:08, 10 June 2013 by JonnyW (talk | contribs) (XML Import to change Variable types into Variable Types)
<sidebar>API contents</sidebar> Expands a macro name to the code generated for the tail of that macro
Class hierarchy
Expand
MacroTail
STRING Source
The macro name to expand
HANDLE Owner
A component that owns the macro
BOOL AddLocals
Tab-indent to generate the code at
BOOL AddTail
Add the macro tail close
STRING
  • Declare a variable 'result' of type STRING
  • Add to a calculation icon:
    result = ::Expand.MacroTail("source", owner, false, true)
