Component: Keypad (Hex 4x4) (Keypad)
Jump to navigationJump to search| Author | Matrix Ltd |
| Category | Keypad |
Keypad (Hex 4x4) component
Preset keypad for entering hexadecimal numbers. Macros 'GetIndex' or 'GetNumber' will return the decimal equivalent of the number pressed, or 255 when no key is pressed. 'GetString' will return the character, including 'ABCDEF'.
Please click here for the component source code: FC_Comp_Source_keypad_hex.fcfx
| WaitPressed | |
| Blocking call that waits for one of the keys on the keypad to be pressed. The index of the key that was pressed is passed back to the user. | |
| GetAscii | |
| Gets the ASCII value for the current keypress. If no key is pressed then the macro returns the value 255. | |
| GetString | |
| Gets the ASCII value for the current keypress and returns in the form of a string. If no key pressed then the macro returns a null string. | |
| GetNumber | |
| Gets the numeric value for the current keypress. If no key pressed then the macro returns the value 255. | |
| GetIndex | |
| Gets the index value for the current keypress. If no key pressed then the macro returns the value 255. | |
| WaitReleased | |
| Blocking call that waits for the keys on the keypad to be released. If no key is pressed then the function will return immediatley. | |
