Component: LED Free (5mm, PCB) ()
Author | Matrix Ltd |
Version | 1.1 |
Category |
LED Free (5mm, PCB) component
An industry standard 5mm diameter LED. Any color may be chosen, and the leads trimmed to length.
Please click here for the component source code: FC_Comp_Source_led_5mm_basic_free.fcfx
